Thread: engine trany won't seperate
Results 1 to 18 of 18
  1. #1 engine trany won't seperate
    Plattsburgh,NY
    help what am I doing wrong engine won't seperate have 3 bolts out of the converter. 4 from engine to tranny all on top side from ground strap back to by exhaust manifold.
  2. #2 Re: engine trany won't seperate
    Banned - Busted For Scamming
    Feb 2009
    thre is a final bolt at the back side of the tranny, you have to use about 2 feet of extensions to get to it. its an 18mm also.
  3. #3 Re: engine trany won't seperate
    Plattsburgh,NY
    what is the genral area do I need to take the tire off to see it. Was looking over the haynes manual again it says something about a tranny to engine brace on right side by oil pan.
  4. #4 Re: engine trany won't seperate
    Feb 2009
    well there is that too, you need to take the passenger side tire off to see the area, then you have to take that bracket off, goes front he differential cover with two bolts to the block with two bolts, take it out then directly behind that you can see the last bellhousing bolt with a light, you will need about 2 feet of extensions to get to it
  5. #5 Re: engine trany won't seperate
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Ah someone forgot the bit(h bolt
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  6. #6 Re: engine trany won't seperate
    May 2008
    McHenry IL
    lol
  7. #7 Re: engine trany won't seperate
    Plattsburgh,NY
    thanks for the help got the engine out. My 12 yr old girl had a blast operating the hoist to raise the engine. I would of never found the bolt without all your help. so how do you get it back in without dropping the bolt or cross threading it.
    Every engineer should have to take apart what they design this one must of been smokin crack when he came up with the hidden bolt.
  8. #8 Re: engine trany won't seperate
    Feb 2009
    to get it back in... take some duct tape and wad it up in the socket so it sticks to it so you can feed it back into the hole, then start it by hand with those extensions, you will be good to go.
  9. #9 Re: engine trany won't seperate
    GTP Level Member Scimmia's Avatar
    QCA, IA
    FWIW, a lot of people don't even put it back in at all.
    2001 Buick Regal LS - Almost Stock
  10. #10 Re: engine trany won't seperate
    Feb 2009
    FAIL
  11. #11 Re: engine trany won't seperate
    FAIL
    Really? Like the Bastardly sized bell housing bolts don't do anything to hold them together LOL
  12. #12 Re: engine trany won't seperate
    Feb 2009
    ehh i dont care, just put the bolt back in, its there for a reason. besides, work at a dealership and do that, when it comes back for a problem ,
  13. #13 Re: engine trany won't seperate
    QCA, IA
    FAIL
    Just saying there are a lot of them out there like that. I wouldn't necessarily recommend it, but really, you've got the diff bracket on that side, what's that bolt really doing?
  14. #14 Re: engine trany won't seperate
    Feb 2009
    holding together the massive amounts of torque the l67 makes lol
  15. #15 Re: engine trany won't seperate
    May 2008
    McHenry IL
    if a bolt came out of something put it back in!!! dont half ass things....
  16. #16 Re: engine trany won't seperate
    Barksdale AFB, LA
    Quote Originally Posted by indyal View Post
    It's not hidden to GM's engineers because they know it's there. So would techs at GM dealerships because the GM SI manual says exactly where it is. They also have specially designed tools for that purpose.
    2009 Subaru Impreza WRX STI
  17. #17 Re: engine trany won't seperate
    i put my ***** bolt back in, but its cross threaded like a mofo so when i (or the next owner) have to take it out again its gonna either break or strip out.
  18. #18 Re: engine trany won't seperate
    Feb 2009
    omg why
  1. trany holding up
    By ionroller in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2008, 01:41 PM
  2. Trany shifts Hard down but easy up
    By jacobmh27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-29-2008, 12:03 PM
  3. Trany whines....I think
    By evlprx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2008, 01:14 PM
