Thread: Not sure what pulley size to get
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Not sure what pulley size to get
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    3.4 pulley here same setup as you, gen v stock heads, n*, headers, Catback, 103, intake, ported lim, 60 injectors, and this is on 91oct. If you have 93, I would just add more timin to it. Personally.
    If You Cant Hear The Whine You're Too Far Behind...
  2. #22 Re: Not sure what pulley size to get
    Banned
    Jan 2013
    Colorado
    gtp 89 do you have aftermarket cams?
  3. #23 Re: Not sure what pulley size to get
    Buena Park Ca
    Yes I have the vs cam. Will be running a 3.2 but on e85 and a 3.4 on 91oct.
  4. #24 Re: Not sure what pulley size to get
    Banned
    Jan 2013
    Colorado
    Alright, I think I'll go with the 3.4 on a genV. How much boost are you running?
  5. #25 Re: Not sure what pulley size to get
    Buena Park Ca
    I believe it is around 8-10 psi of boost 10 being the max the car is sitting due to my tranny going out so I literally drove it for about 2 weeks once the tune got done. Personally if I were you buy a 3.4 and a 3.3 and a 3.5 to be able to switch them out and see which works best, because at the end it isn't the size of the pulley but other factors that make a bigger difference like timing.
  6. #26 Re: Not sure what pulley size to get
    Banned
    Jan 2013
    Colorado
    I would have to get 3 different belts then.
  7. #27 Re: Not sure what pulley size to get
    Buena Park Ca
    Just a thought. Not something that has to be done.
  8. #28 Re: Not sure what pulley size to get
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Quote Originally Posted by camopaint0707 View Post
    Problem is that zzp's modular pullies go from 3.4 to 3.25
    Huh? You can get a 3.25, 3.2, and a 3.1.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  9. #29 Re: Not sure what pulley size to get
    Banned
    Jan 2013
    Colorado
    Exactly, you can't get a 3.3
  10. #30 Re: Not sure what pulley size to get
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    You can get a 3.3 and I believe a 660 belt will fit all pulleys from a 3.2 - 3.5 so no need for a belt per pulley...
    Click on the drop down, Intense has 2.5 - 3.6 all in .1 increases. Intense pulleys will fit on ZZP hubs as well and vise versa.
    INTENSE-Racing.com: INTENSEā„¢ Eaton M90 Individual Modular Supercharger Pulley
    http://www.grandprixforums.net/engin...hart-2486.html
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  11. #31 Re: Not sure what pulley size to get
    Banned
    Jan 2013
    Colorado
    I might do that then
  1. VS cam pulley size?
    By Swiggles in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2012, 06:42 AM
  2. What size pulley should I buy?
    By Kejross in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2011, 09:58 AM
  3. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  4. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  5. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
