Thread: cps and harmonic balancer replacement problems case learn needed?
Results 1 to 12 of 12
Threaded View
  1. #1 cps and harmonic balancer replacement problems case learn needed?
    May 2013
    new port richey florida
    2001 pontiac grand prix gtp
    Original symptoms:
    Regular driving tach goes to zero no cel
    Regular driving car stutters no cel
    Took excessive amounts to start key on key off cars starts (very rarely did this).
    Car rarely throw cel and was gone before i could check.
    Parts changed:
    Pulled harmonic balancer and replaced.
    Pulled off crank position sensor replaced it.
    Bolt on end showed wear on 1 thread replaced it with bolt from ace Hardware
    Following results:
    After replacing of all parts start car everything runs good. Drive it 5 miles that day.
    Next day car drive good but after about 20 miles car begins to have stutters as before but occuring in few second intervals as well rpm surge between 500 and 1700 car sounds like its going to stall
    What I have done to fix problem:
    Pull neg battery terminal restart car.
    Results: first time fixed it only for a minute. Next time enought to get me about 5 miles.
    3rd time it has not done the stuttering since and put about 20 miles on in 3 different trips.
    Could this be a result of needing a case learn or is something else massively wrong?
    Case learn is $100 and not trying to throw money at the wrong problem
    Car has no cel on
  1. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
  2. harmonic balancer removal
    By ericg1181 in forum General Tech Discussion
    Last Post: 08-05-2012, 12:38 PM
  3. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  4. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
