Thread: cps and harmonic balancer replacement problems case learn needed?
Results 1 to 12 of 12
  1. #1 cps and harmonic balancer replacement problems case learn needed?
    May 2013
    new port richey florida
    2001 pontiac grand prix gtp
    Original symptoms:
    Regular driving tach goes to zero no cel
    Regular driving car stutters no cel
    Took excessive amounts to start key on key off cars starts (very rarely did this).
    Car rarely throw cel and was gone before i could check.
    Parts changed:
    Pulled harmonic balancer and replaced.
    Pulled off crank position sensor replaced it.
    Bolt on end showed wear on 1 thread replaced it with bolt from ace Hardware
    Following results:
    After replacing of all parts start car everything runs good. Drive it 5 miles that day.
    Next day car drive good but after about 20 miles car begins to have stutters as before but occuring in few second intervals as well rpm surge between 500 and 1700 car sounds like its going to stall
    What I have done to fix problem:
    Pull neg battery terminal restart car.
    Results: first time fixed it only for a minute. Next time enought to get me about 5 miles.
    3rd time it has not done the stuttering since and put about 20 miles on in 3 different trips.
    Could this be a result of needing a case learn or is something else massively wrong?
    Case learn is $100 and not trying to throw money at the wrong problem
    Car has no cel on
  2. #2 Re: cps and harmonic balancer replacement problems case learn needed?
    Which engine are we talking about? Since the car runs, please have it scanned. Hopefully they'll see the history code that is stored.
  3. #3 Re: cps and harmonic balancer replacement problems case learn needed?
    May 2013
    Sorry ill try to have it scanned but I have
    Pulled battery so I think that clears the codes.
    Car did it again after trying to drive to school about 30 miles away.
    I took a video of it
    https://www.youtube.com/watch?v=I7GR...e_gdata_player
    It appears it maybe unrelated to the cps because it could be related to putting gas in the car.
    It seems that letting the car sit fixes it.
    Possible clogged fuel filter?
  4. #4 Re: cps and harmonic balancer replacement problems case learn needed?
    May 2013
    Car is a 2001 pontiac grand prix gtp stock to my knowledge except 180 t stat
    Built in june I believe
  5. #5 Re: cps and harmonic balancer replacement problems case learn needed?
    Can't see the vid... skip what I originally wrote
  6. #6 Re: cps and harmonic balancer replacement problems case learn needed?
    Aug 2011
    Millbury, OH
    Who made the CPS sensor? Case learn might be needed buy why is it 100 bucks?
    2000 GTP coupe, Stattama Turbo Setup, A/A intercooled, custom cam, Tischler heads, 3250 stall, Zzp trans, 1" GMR chain, 65# injectors MDP hood, MSP exhaust, and much more.
  7. #7 Re: cps and harmonic balancer replacement problems case learn needed?
    May 2013
    Is the vid working?
    Case learn is about 100 from a dealer but my buddy my be able to get a snapon scanner.
    Going to change fuel filter and see if that helps
  8. #8 Re: cps and harmonic balancer replacement problems case learn needed?
    St. Louis
    FYI, that 180* thermostat is only going to hurt fuel mileage and not give any better cooling unless you are tuned for it, as the stock fan turn-on points are still at the 195* range...
  9. #9 Re: cps and harmonic balancer replacement problems case learn needed?
    May 2013
    The previous owner put it in im going to just leave it cause the plan is to turbo it and eventally get hp tuner for that.
    Its looking like the car needs some basic maintenance filters and wires (wire show signs of arc near contact with metal)
    The fuel filter definitely showed a noticeable difference as soon as I started it seems to idle smoother hopefully thats the mystery problem.
    Being on the jack for a while may have caused trash to get picked up.
    Thanks to all that helped
  10. #10 Re: cps and harmonic balancer replacement problems case learn needed?
    May 2013
    Well car continues to have same problem
    Appears to be link to after the car is hot.
    Had an tech 2 scanner on it today and every thing seems normal. Unfortunately I am an idiot and never did the case learn but at this point im thinking this is not the case.
    Ltft were 3 and stft stay about 0
    Knock retard when the car was wot was 3
    When the car began surging the mv for the front o2 were jumping around.
    Car has white residue on exhaust tips and pulled a plug and was pretty white.
    Car seems to run lean during sputter
    Car ran fine when cool and wot had no problems smooth.
    Just changed plug wires
    When problem occured unplugged
    Maf sensor problem not solved
    Unplugged o2 sensor problem not solved
    Could this be
    Icm or coil pack?
    Or dredged lim gasket?
    Car does not seem to do it if hood open and just idle
  11. #11 Re: cps and harmonic balancer replacement problems case learn needed?
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    I'm having similar issues. Have you figure anything else out on this?
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  12. #12 Re: cps and harmonic balancer replacement problems case learn needed?
    May 2013
    Problem was solve it appears
    Faulty replacement cps
    Put new one in and has been fine for last couple days.
    The heat may have been shorting out the signal.
  1. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
  2. harmonic balancer removal
    By ericg1181 in forum General Tech Discussion
    Last Post: 08-05-2012, 12:38 PM
  3. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  4. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
