Heres whats wrong and hopefully someone will have an answer.
My 97 gtp has been getting air pockets in the cooling system, causing it to blow the coolant into the overflow and over heat. There is a few wet spots ive noticed on the side of the block, under the s/c snout in the area where the lower intake gaskets are. My car does not smoke, there is no coolant in the oil, but its getting air in the coolant. Not long after it gets up to temperature the gauge just keeps going and itll overheat but by that time ive already shut the car back off.. Does this sound like intake gaskets or head gaskets. Please help![]()
