Thread: Idle issues after LIM gasket replacement
Results 1 to 4 of 4
  1. #1 Idle issues after LIM gasket replacement
    SE Level Member eshina17's Avatar
    Dec 2011
    Marquette, MI
    Alright so the other day I replaced my intake manifold gasket, and after I finished, she started right up. However, the RPMs were running very high initially. Im assuming thats somewhat normal tho. After running for a while and reaching and idle, it was apparent it was not idling correctly. I did notice while doing the repair that a few of my vacuum hoses were cracked by the base. Could this idle issue just be because of the vacuum lines? Im just hoping i didnt screw anything up while doing the gasket replacement... Any help is appreciated!
    1987 Pontiac Fiero 2M4 - Sold
    2002 Dodge Stratus R/T - Piece of ****! - SOLD
    1997 Pontiac Grand Prix GTP L67
  2. #2 Re: Idle issues after LIM gasket replacement
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    How bad were the cracks? If bad enough to not seal tightly and allowing your motor to suck in unmetered air, yep that will do it. Fix your vacuum boots and make sure you have no other vacuum leaks and you should be set!!
    If you want, go to the parts store and get an assortment pack of vacuum pieces along with some new vacuum line and redo it all.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  3. #3 Re: Idle issues after LIM gasket replacement
    best to just go buy 4 feet of new vac tubing and 2 new T's, costs around 5 bucks with the T's to do most of the problem lines.
    for the line still on the vac tree's that are plastic, its best to cut them off with a new sharp razor, support under the line and then slice it. the plastic vac tree parts can break quite easy if your not careful .
  4. #4 Re: Idle issues after LIM gasket replacement
    You know the vac lines are the issue. Clear them up and that should be good.
  1. High Idle Problems (After Intake Gasket Replacement)
    By zmaddox5306 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-10-2013, 07:46 PM
  2. Intake manifold gasket replacement now high idle
    By coreyrcflyer77 in forum Introductions/Noob Questions
    Last Post: 02-02-2013, 06:47 AM
  3. Idle problem after LIM replacement
    By AaronStaub in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2011, 10:44 PM
  4. Help.. Strange Idle (video) after 1.9's/LIM gasket -
    By Brooks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 06:33 PM
  5. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
