Thread: Whining sound power steering ?
Results 1 to 16 of 16
  1. #1 Whining sound power steering ?
    Nov 2008
    Redwood city
    I have had a low whining sound that increases with rpm. It sounds like the power steering but I am not sure. I just replaced the steering pump and the sound is still there. I hear it at idle when reving . and at low speeds. Is this a common sound for Gm power steering.
  2. #2 Re: Whining sound power steering ?
    Jul 2008
    Poteau Oklahoma
    is your car supercharged? if yes then that is more than likely your whine.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  3. #3 Re: Whining sound power steering ?
    Feb 2008
    Quote Originally Posted by JC2000GTP View Post
    I hear it at idle when reving.
    That's talent right there!
    Your description is a little confusing. Can you hear it at idle or while you are revving? If at idle, it's most likely your P/S. If while revving it could be your P/S or your S/C.
  4. #4 Re: Whining sound power steering ?
    Nov 2008
    Redwood city
    It is noticable at idle when you rev engine or turn the steering back and fourth. Its the same sound I had before I changed the pump. I bought a napa pump. Rebuilt. I can hear my supercharger whine completly different sound.
  5. #5 Re: Whining sound power steering ?
    GT Level Member GTPRiley's Avatar
    Oct 2008
    Abilene Texas
    easy fix, add more fluid!
    Riley Greear
    "Bastardized" 2004 Grand Prix GTP Comp G. 180* Tstat, Fender Well Intake, AL 104's SSAC Headers 3.5 MPS XP-HOT Cam and 105# springs.
  6. #6 Re: Whining sound power steering ?
    Nov 2008
    Redwood city
    Its Full ! Its New And its Been flushed.
  7. #7 Re: Whining sound power steering ?
    Jul 2008
    Poteau Oklahoma
    power steering....well the lines need to be bled.
    get both front wheels off the ground, make sure the resivour is full, and with the engine not running, turn the wheels lock to lock and back 15 times all the air should be gone if not repeat.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  8. #8 Re: Whining sound power steering ?
    Nov 2008
    Redwood city
    Thanks I have done that. I was just wondering if people have had trouble with these pumps.
  9. #9 Re: Whining sound power steering ?
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by justwhisen View Post
    actually, its better to keep the car on the ground and turn the steering wheel almost at lock to lock. ( meaning right before it locks throw the steering wheel the other way and repeat process until the noise is gone) you can do bad things to a pump by hitting the locks. also have the cap removed when bleeding almost as a vent. the car needs to be running to bleed the system. turn the car off and re-check. if you add to little you'll be sucking air all over so over fill it slightly but not to the point where its dumping out. watch for bubbles. bubbles indicate air
    COMP G
  10. #10 Re: Whining sound power steering ?
    Nov 2008
    Redwood city
    Thanks I have done all these things. I am now told by a parts tech that I have air in system. He wants me to pull a vaccum on the resevoir and turn the wheel while running.
  11. #11 Re: Whining sound power steering ?
    Feb 2008
    It is possible that you got a bad rebuilt pump. I would take it to them so they can hear it and demand a new one.
  12. #12 Re: Whining sound power steering ?
    Oct 2008
    Abilene Texas
    Indeed and JC I wasnt insulting your intelligence, some ppl, including myself can look over the simplest things lol.
    Riley Greear
  13. #13 Re: Whining sound power steering ?
    Nov 2008
    Redwood city
    Thanks for all the replys!
  14. #14 Re: Whining sound power steering ?
    TDCRacing
    Guest
    Yeah i'd just bring it back. They shouldnt have a problem returning it no questions asked becuase most everything you buy for you're car from an auto parts store has a lifetime waranty on it. Wich is nice.
  15. #15 Re: Whining sound power steering ?
    Nov 2008
    Redwood city
    Just replaced second pump. Delco rebuilt. Still have noise.
  16. #16 Re: Whining sound power steering ?
    Jul 2008
    El Paso
    What about the belt tensioner... Could the pully have a bad bearing..... Also Could be your alternator's bearings going out. Try getting a Mechanics stethoscope and have someone rev the engine to help pin point the location. Im having the same whine on my car and I already replaced the alternator, and now think its the tensioner pully bearing.
  1. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
  2. Power Steering fluid leak
    By jokyfo in forum General Tech Discussion
    Last Post: 09-28-2008, 11:24 PM
  3. Power Steering
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:01 PM
  4. Power Steering Rack replacement 98 GT
    By Fritcr in forum General Tech Discussion
    Last Post: 04-27-2008, 06:03 PM
  5. power steering
    By Toasty in forum General Tech Discussion
    Last Post: 02-23-2008, 01:24 PM
