Thread: Electrical issues Need help
Results 1 to 10 of 10
  1. #1 Electrical issues Need help
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    Hey, well im here again but now its something else =[ well my left turn signal turns on but my other one on the right wont turn on
    also my headlights wont turn on either and when i press the horn it doesnt honk but instead have my 2 turn signal lights inside the instrument cluster turn on. oh and also when i turn the turn signal on both turn signals light up in the instrument cluster.
    Any ideas. im currently checking fuses but all look good so far
    99 grand prix gtp
  2. #2 Re: Electrical issues Need help
    Jan 2013
    west palm
    Any ideas????????????????????????????????????????????? ????????????????????
  3. #3 Re: Electrical issues Need help
    You likely didn't get responses because you didn't provide much information. Let's change that.
    Have you had other electrical problems in the past?
    Do you drive a car? If so.. what is it.. year/model please.
    Was your car fine before an accident or did this suddenly happen?
  4. #4 Re: Electrical issues Need help
    rochester
    Check your grounds mainly from battery to the body.
  5. #5 Re: Electrical issues Need help
    bad grounds to the engine, theres 2 grounds on the bell housing of the trans. or bad ignition harness are my votes.
  6. #6 Re: Electrical issues Need help
    Jan 2013
    west palm
    alas I to think it is my igniton harness.
    and its a 99 gtp and i changed the crank pos and harmonic balancer and it never did this before i did that
    Today i drove it and the fans wouldnt even come on and i had to let the car cool off before i could restart it.
    Whats a pain......
    Does the ignition switch/harness control the fans as well?
  7. #7 Re: Electrical issues Need help
    check the grounds on the trans bell housing first, make sure theres 3 ground wires all attached still and they are tight. and the battery cables to the battery are clean and tight.
    if all that looks good, the ignition harness makes all sorts of stuff not work, a/c / heat fan is one of them. head lights, and so on.
    they aren't cheap so a used one from a part out maybe a good idea. they are not to bad to change either, looks and sounds worse then it really is.
  8. #8 Re: Electrical issues Need help
    Jan 2013
    west palm
    Car problems electrical nick - YouTube
    Heres a video of this problem
    any other advice would be great
  9. #9 Re: Electrical issues Need help
    Jan 2013
    west palm
    this is the problem could you check it out thanks.
  10. #10 Re: Electrical issues Need help
    Quote Originally Posted by titanfan12 View Post
    Negative ghostrider... we suggest you check the grounds and let us know if you find anything,.
  1. Need help. Possible electrical issues
    By itsCOMPlicated in forum General Tech Discussion
    Last Post: 05-22-2013, 10:31 AM
  2. Electrical issues when wet
    By Kyle Dixon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2013, 06:42 PM
  3. Help! Electrical issues!
    By mrfreez in forum General Tech Discussion
    Last Post: 04-13-2013, 10:36 AM
  4. Electrical Issues
    By DStepien in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2012, 10:06 PM
  5. Various Electrical Issues
    By BlackGT1 in forum General Tech Discussion
    Last Post: 09-21-2011, 01:25 PM
