Thread: 2005 GP Changing system failure warning came on DIC during a WOT run.
Results 1 to 9 of 9
  1. #1 2005 GP Changing system failure warning came on DIC during a WOT run.
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Just like the title says. I did a WOT run and the Changing system failure warning came on the DIC. I cleared the message to check the voltage still at WOT and saw it at 10.90 and dropping, I let off and it shot right back up to 14.8? Any input? alt is failing?
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: 2005 GP Changing system failure warning came on DIC during a WOT run.
    sounds like it is. unless the ripped out wires from the icm have something to do with it.......
  3. #3 Re: 2005 GP Changing system failure warning came on DIC during a WOT run.
    Apr 2012
    Middletown DE
    this was before that.. lol before the lifter even stated tapping.. btw that bad lifter if you shake it it makes a rattling sound.. lol
    1993 Oldmobile 88
  4. #4 Re: 2005 GP Changing system failure warning came on DIC during a WOT run.
    Diagnosing the same way I do huh?
  5. #5 Re: 2005 GP Changing system failure warning came on DIC during a WOT run.
    ouch thats not so good. yeah looks like its alt time.
    i just changed mine the other day, called a local re builder cost 80 bucks from them, vs over a 100 or more everywhere else. the best i could find from a store was advance with a code i got it to 100.
    not sure what alt the 05's got but i found a rebuild kit for mine, cs130D alt <<whats on a 98. for 40 bucks, problem is you need a press to get the bearings out of the cars, unless you just swap out the regulator and brushes, VERY EASY LOOKING TO DO BTW. they dont cost a lot either.
  6. Likes LouF liked this post
  7. #6 Re: 2005 GP Changing system failure warning came on DIC during a WOT run.
    SWPA
    Maybe the belt just needs tightening? Maybe going WOT made the belt slip. Slipping belt = no charge.
  8. Likes LouF liked this post
  9. #7 Re: 2005 GP Changing system failure warning came on DIC during a WOT run.
    St. Louis
    Being that it only happens at WOT, is it possible that the belt is slipping and thus not allowing the alt to keep up? Not saying the alt isn't dying, just wondering...
  10. #8 Re: 2005 GP Changing system failure warning came on DIC during a WOT run.
    Apr 2012
    Middletown DE
    It has a brand new belt... This car has always had weird electrical issues, scotty probably remembers som of my older posts about them.
    found this on rock auto
    Electrical : Alternator / GeneratorRelated Parts
    ACDELCO Part # 20757890 125 Amps
    Generator
    $123.79
    1993 Oldmobile 88
  11. #9 Re: 2005 GP Changing system failure warning came on DIC during a WOT run.
    google starter and alternator re builders in your area. they are far cheaper, and local, if they dont have one in stock you drop yours off, they can re build it in hours most of the time. they are local too so no shipping fees, same day service too.
  1. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  2. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  3. Charging Sytem Failure Warning
    By 07GP316 in forum General Tech Discussion
    Last Post: 02-20-2011, 01:18 PM
  4. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
