Thread: Crazy oil pressure
Results 1 to 17 of 17
  1. #1 Crazy oil pressure
    Grand Island, Nebraska
    I've been having a strange problem with my gp for about a month now (I probably ignored it too long). At start up, my electric oil pressure gauge will do the normal sweep, and then peg at 0. Doesn't change if I rev it. After it gets warmed up the pressure will sometimes be 70 which is what it usually is or somewhere around 40. It will also randomly peg 0 or 100 while driving. I have a video of it staying around 40 cruising, then jumping to 70, and switching between those two , then going to like 3 psi, all while cruising. And sometimes if its at like 30 and I rev it to try to go up it just pegs 0 again. What is going on?
  2. #2 Re: Crazy oil pressure
    Either a short to ground or its losing power.
    Or the oil pressure sendor itself is on the fritz.
  3. #3 Re: Crazy oil pressure
    Ohio
    id say short somewhere
  4. #4 Re: Crazy oil pressure
    Ok that's what I was hoping, it's not wired very well. I'll have to redo it and see what happens. Would my motor have blown by now with real oil pressure like that?
  5. #5 Re: Crazy oil pressure
    Ohio
    yeah lol 3 psi...
    you would hear the rave going on in your oil pan
  6. #6 Re: Crazy oil pressure
    Could there be a clog or something near the sensor? Because the needle still kinda wiggles like its on when it's at 3psi
  7. #7 Re: Crazy oil pressure
    Ohio
    i doubt it.
  8. #8 Re: Crazy oil pressure
    May 2008
    Schuyler, NE
    I'm betting you have a bad ground.
  9. #9 Re: Crazy oil pressure
    Wat u no about oil pressure guy u dun even haz headers
  10. #10 Re: Crazy oil pressure
    May 2008
    Schuyler, NE
    Throw some headers on. That'll fix everything.
  11. #11 Re: Crazy oil pressure
    Quote Originally Posted by JoRoW99 View Post
    Problem exists between steering wheel and seat. Fix the known issue before you try to diagnose the known issue as another issue, like a clog etc.
  12. #12 Re: Crazy oil pressure
    Yea I started fixing it, I correctly spliced and soldered the gauge power wire into a pink ignition wire instead of the DRL power wire. It looks to be grounded well, the same place as another stock wire, but I'm going to move it and see if has any effect. If that doesn't work I'll hook up the stock dummy light to see if it is really reading less than 5psi.
  13. #13 Re: Crazy oil pressure
    If it reads less than 5psi..you'll hear the noise sooner than you'll read the pressure.
  14. #14 Re: Crazy oil pressure
    May 2008
    Schuyler, NE
    And, if that happens, you better sell me the car for cheeeeeaaaaaaapppppp!
  15. #15 Re: Crazy oil pressure
    Nah you wouldn't like it, it has headers. You should be the one selling me an l67 for cheeeeeap.
  16. #16 Re: Crazy oil pressure
    Ok so uhh I googled autometer oil pressure sender and that is not what I have installed...it looks like an autometer fuel pressure sender.
  17. #17 Re: Crazy oil pressure
    ahahahahaha
  1. Help it's going crazy!!!!
    By mudneck4 in forum Introductions/Noob Questions
    Last Post: 05-02-2013, 08:44 PM
  2. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  3. This is crazy
    By Ricky21 in forum Off Topic Discussion
    Last Post: 09-21-2010, 08:10 PM
  4. This is crazy
    By 40mphGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 07:32 PM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
