My car is a 98 GTP and it doesnt make full boost when it is warm but when it is cold it can boost all the way. any ideas? I already replaced the bbv. Car has headers full exhaust and cai. Plus i got a SD hood.![]()
Are you basing boost level on lego blocks or do you have an actual boost gauge?
On the lego blocks
When I put headers in both my GTPs, I never made "full boost" according to the block. But on my Boost gauge I was between 6-7PSI.
You're not building as much boost, but you are flowing better.
What about when i start the car cold and i punch it, it shows full boost and i can actually feel the car way faster. But when it is warmed up and i punch it it doesnt show all the lego blocks and the car feels slower.?
i have no cat though. well the car is not really cold cold
can it be fuel related?
No, is cel free. except for the dam "low coolant" but thats because my sensor is bad.
Did this start before or after you replaced the BBV? If you install the lever wrong, you won't hit full boost.
i changed the bbv because i though it would fix the problem put it didnt.
Change your SC Belt, look for Vac Leaks. Maybe your just knocking too much. I think someone mentioned KR Sensor activates at 160*. Dont quote me on that though.
Intake and headers without a tune? Might be running lean and retarding timing. It might also be worth checking out your mass airflow sensor (MAF).
Mind telling me what is the KR Sensor? Im planning to take it to a dyno to get it properly tuned up.
Knock Retard Sensor.
Reason why you get full boost and faster when cold is because the KR sensor isn't activated. So you can knock for days, and nothing is going to stop it.
When warm, the KR sensor monitors the engine. My guess is you are knocking, and the engine is retarding greatly to prevent you from blowing it up.
So replacing the kr sensor would be useless right?
yes. it is helping you. if you are having too much knock it is keeping you from screwing your engine up.
if it is knock and the car is retarding the timing. you have a problem that is causing the knock. you will have to hook it up to a scanner while driving it to find out how much knock.
did this just start or something?
maybe you need different spark plugs.
No this been happening like 3-5 months ago maybe a little longer. Ill have a look at my plugs tomorrow.
