Thread: Supercharger boosting half way when warm?
Results 1 to 20 of 30
  1. #1 Supercharger boosting half way when warm?
    Apr 2013
    LA
    My car is a 98 GTP and it doesnt make full boost when it is warm but when it is cold it can boost all the way. any ideas? I already replaced the bbv. Car has headers full exhaust and cai. Plus i got a SD hood.
  2. #2 Re: Supercharger boosting half way when warm?
    Omaha, NE
    Are you basing boost level on lego blocks or do you have an actual boost gauge?
  3. #3 Re: Supercharger boosting half way when warm?
    Apr 2013
    LA
    On the lego blocks
  4. #4 Re: Supercharger boosting half way when warm?
    Florida
    When I put headers in both my GTPs, I never made "full boost" according to the block. But on my Boost gauge I was between 6-7PSI.
    You're not building as much boost, but you are flowing better.
  5. #5 Re: Supercharger boosting half way when warm?
    Sounds like you need a real vacuum/boost gauge.
    But I am thinking you have a different problem here.
  6. #6 Re: Supercharger boosting half way when warm?
    Apr 2013
    LA
    What about when i start the car cold and i punch it, it shows full boost and i can actually feel the car way faster. But when it is warmed up and i punch it it doesnt show all the lego blocks and the car feels slower.?
  7. #7 Re: Supercharger boosting half way when warm?
    Clogged exhaust.
    And I wouldnt romp on the car when cold, its not really good for it.
  8. #8 Re: Supercharger boosting half way when warm?
    Apr 2013
    LA
    i have no cat though. well the car is not really cold cold
    can it be fuel related?
  9. #9 Re: Supercharger boosting half way when warm?
    Maybe.
    If you don't have any gauges to monitor the car then its really hard to say what it going on.
    And codes?
  10. #10 Re: Supercharger boosting half way when warm?
    Apr 2013
    LA
    No, is cel free. except for the dam "low coolant" but thats because my sensor is bad.
  11. #11 Re: Supercharger boosting half way when warm?
    Omaha, NE
    Did this start before or after you replaced the BBV? If you install the lever wrong, you won't hit full boost.
  12. #12 Re: Supercharger boosting half way when warm?
    Apr 2013
    LA
    i changed the bbv because i though it would fix the problem put it didnt.
  13. #13 Re: Supercharger boosting half way when warm?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Change your SC Belt, look for Vac Leaks. Maybe your just knocking too much. I think someone mentioned KR Sensor activates at 160*. Dont quote me on that though.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  14. #14 Re: Supercharger boosting half way when warm?
    Pennsylvania
    Intake and headers without a tune? Might be running lean and retarding timing. It might also be worth checking out your mass airflow sensor (MAF).
  15. #15 Re: Supercharger boosting half way when warm?
    Apr 2013
    LA
    Mind telling me what is the KR Sensor? Im planning to take it to a dyno to get it properly tuned up.
  16. #16 Re: Supercharger boosting half way when warm?
    Kansas
    Knock Retard Sensor.
    Reason why you get full boost and faster when cold is because the KR sensor isn't activated. So you can knock for days, and nothing is going to stop it.
    When warm, the KR sensor monitors the engine. My guess is you are knocking, and the engine is retarding greatly to prevent you from blowing it up.
  17. #17 Re: Supercharger boosting half way when warm?
    Apr 2013
    LA
    So replacing the kr sensor would be useless right?
  18. #18 Re: Supercharger boosting half way when warm?
    GT Level Member Shiftingshaddow's Avatar
    KC
    yes. it is helping you. if you are having too much knock it is keeping you from screwing your engine up.
    if it is knock and the car is retarding the timing. you have a problem that is causing the knock. you will have to hook it up to a scanner while driving it to find out how much knock.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  19. #19 Re: Supercharger boosting half way when warm?
    KC
    did this just start or something?
    maybe you need different spark plugs.
  20. #20 Re: Supercharger boosting half way when warm?
    Apr 2013
    LA
    No this been happening like 3-5 months ago maybe a little longer. Ill have a look at my plugs tomorrow.
  1. muliptle misfire code when boosting
    By johannib in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2013, 06:06 AM
  2. Only getting half boost on DIC.
    By ls1racer11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2012, 11:40 PM
  3. wondering if I can run a 3.4 pulley on my car by boosting octane?
    By blazer316 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 10:05 AM
  4. Boosting Under Load? Normal?
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 03:05 PM
  5. Boosting Pulley size
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 05:07 PM
