Thread: comp cam reusable rocker arm bolts question?
Results 1 to 9 of 9
  1. #1 comp cam reusable rocker arm bolts question?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    i recenty got a set of comp cams reusable rocker arm bolts. after looking at the oem ones there seems to be a biult in washer on them. the comp cam bolts do not. my question is do i need to put a washer on the comp bolts? or just leave them how they are. Comp Cams - Re-usable Rocker bolts #COMP-1053B-12 these are what mi talking about
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: comp cam reusable rocker arm bolts question?
    I didn't use a washer.
  3. #3 Re: comp cam reusable rocker arm bolts question?
    Sep 2011
    palm harbor florida
    do they have to be torqued in a specific sequence?
  4. #4 Re: comp cam reusable rocker arm bolts question?
    May 2008
    Schuyler, NE
    No. The valve is supposed to be closed for torquing them down though.
  5. #5 Re: comp cam reusable rocker arm bolts question?
    Oh ****, well that info could have been use full like 3 months ago.
  6. #6 Re: comp cam reusable rocker arm bolts question?
    Pennsylvania
    That's the proper way to do it, but on our motors with stock lifters, they have a much broader acceptable preload, so having the valves closed for each rocker isn't important for our motors. That's what a bunch of credible sources told me anyways..
    If you got comp lifters or some other aftermarket, their preload tolerance is way tighter so its more important to move each cylinder to tdc on the compression stroke.
    I didn't have any issues just swapping out the arms from left to right.
    25lb-ft on each bolt, I used blue thread locker for peace of mind, and you're good.
    Sport Edition Kv5 18x8
  7. #7 Re: comp cam reusable rocker arm bolts question?
    SE Level Member sco77's Avatar
    MD
    I torqued them as close to TDC as possible, I did this by holding a feeler in the spark plug hole as I rotated the engine. Of course this is on an engine stand, might be pretty hard to do in a car.... But I don't think it's required on these engines.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  8. #8 Re: comp cam reusable rocker arm bolts question?
    May 2008
    Schuyler, NE
    The only reason you're supposed to keep the valves closed, is so you get a more accurate torque reading without having tension on teh spring. I rarely ever rotate the motor so each valve is closed.
  9. #9 Re: comp cam reusable rocker arm bolts question?
    Sep 2011
    palm harbor florida
    ya i made sure each valve was fully closed and torqued them to 23 foot lbs... and i just realized that i forgot thread locker.
  1. Comp Cams Re-useable rocker bolts - torque spec?
    By Elite6 in forum General Tech Discussion
    Last Post: 07-14-2012, 02:51 PM
  2. Comp cams 5/16" rocker bolts
    By tod1d in forum General Tech Discussion
    Last Post: 12-23-2011, 02:17 PM
  3. rocker bolts
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2011, 08:43 PM
  4. Rocker Arm Bolts
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2010, 10:01 PM
