If the IAC moves at all chances are it probably works make sure it doesn't stay at 185 all the time or u need a new iac. You said u checked for vac leak did u use carb cleaner? Or eyes? Lim, t fitting under sc snout, tb gasket, vac going to your map sensor are main places to look also what is your map reading
