Thread: More engine problems..
Results 1 to 14 of 14
  1. #1 More engine problems..
    Mar 2013
    Spring, TX
    So randomly my car has started leaking what appears to be oil.. It's never leaked a drop of anything the past two months i've owned it until just the other day. I got under the car today to change the oil and noticed the leaking was coming from around the trans pan area. The pan wasn't leaking but something above it had soaked everything all the way down and it was dripping now. The whole front axle appeared to be covered and dripping with what appears to be oil. So I changed the oil and put the car back down and backed it out and looked under the hood and noticed under throttle a tiny bit of smoke appears from the rear-passenger side of the engine. Just a little smoke and only under throttle.. I also heard a lot of light rattling which I thought was just a noisy pulley since I had just changed the coupler in my supercharger but now i'm not so sure.. Any ideas? Please help..
  2. #2 Re: More engine problems..
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Valve cover gaskets? That can leak all the way down the back of the engine. Can cause smoke with oil leaking onto the hot exhaust.
    Only while revving? More exhaust flow whole revving means hotter exhaust so more smoke.
    That's my guess.
  3. #3 Re: More engine problems..
    Mar 2013
    Spring, TX
    Thats what I thought.. My truck did that at one time. I just thought it was strange that one day it was fine and the next, bam.
  4. #4 Re: More engine problems..
    Run your finger under the edge of the valve cover edge. Is is leaking?
    I know.. it seems too simple of a test to diagnose it, life doesn't have to be difficult.
  5. #5 Re: More engine problems..
    Pennsylvania
    You can also use a paper towel if you're not an uncivilized animal.
  6. #6 Re: More engine problems..
    Quote Originally Posted by SlowNA06 View Post
    It wasn't my finger that was gonna get oily and nasty..lol
  7. #7 Re: More engine problems..
    if the pass side axle was wet with oil, im voting oil pressure sensor blew out, its in the oil filter housing.
  8. #8 Re: More engine problems..
    Apr 2009
    Maine
    This. I've had that thing blow about once a year since I've had my car.
  9. #9 Re: More engine problems..
    Quote Originally Posted by J GTP View Post
    Are you and Dogger related?
  10. #10 Re: More engine problems..
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    If not maybe the high pressure PS line with a pinhole.
  11. #11 Re: More engine problems..
    i blew 3 of them, i now have a brass plug in the hole, im not wasting another 12 bucks on a new one.
  12. #12 Re: More engine problems..
    Mar 2013
    Spring, TX
    I got it checked out by the shop I bought the car from. He said it was just leaking from the oil pan and its a normal thing.. It was all clean up by the oil filter. I checked up by the valve cover and it didn't really seem oily but more just dirty.. He said he didn't think it was the valve cover and was pretty sure it was just the pan leaking a little. He drives a grand prix gt and says his leaks a little from the same place too. Sound right?
  13. #13 Re: More engine problems..
    3800 engines are known to leak oil. oil pans leak all the time.
  14. #14 Re: More engine problems..
    Mar 2013
    Spring, TX
    Thats what I figured. I just thought it was weird that it was all over the place.
  1. Engine problems.......
    By draftrcn in forum General Grand Prix Discussion
    Last Post: 09-01-2012, 07:32 PM
  2. Engine problems
    By mattstansbury in forum General Tech Discussion
    Last Post: 10-07-2011, 05:33 PM
  3. engine code problems
    By yeacashgpgt2002 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2011, 06:08 AM
  4. Engine problems
    By kenizzle36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2011, 09:57 AM
  5. Engine swap done, problems
    By atruebudfan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2009, 01:48 AM
