Thread: Low boost, any ideas?
Results 1 to 14 of 14
  1. #1 Re: Low boost, any ideas?
    May 2013
    Florida
    Quote Originally Posted by Reverant GTP View Post
    Just thought i'd give a little update on this. I have an air intake with the cone right on the maf tube just like everyone else. Well i decided to put the maf tube on the throttle body and have a stretch of tube before the maf. What a difference it made! I now get all but the last bar on my factory boost guage. So still searching that issue but decided i'm gonna wait until i change intake gaskets since they are leaking. I also dont get a constant 3-4 degrees of kr. Its erratic but out of ten pulls 7 were 1-2 degrees and the others were 2-3. I still get a very occasional 4 and spike 6 however on one. My o2 b1 is lower also which is around 890-930 depending on the pull. Still running negative fuel trims however and for some reason 100% injector duty on shifts however it is better than previous intake setup where it was 106% on shifts. I'm not sure if that injector duty cycle is normal on a stock car with just an intake?
    U lost me. What do u mean stretch tube?
  2. #2 Re: Low boost, any ideas?
    SE Level Member Reverant GTP's Avatar
    Iowa
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. tattoo ideas for my cast! post your ideas!
    By putskijr in forum Off Topic Discussion
    Last Post: 07-11-2010, 04:53 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
