Thread: should i get rid of my balance shaft gear with a vs cam?
Results 1 to 13 of 13
  1. #1 should i get rid of my balance shaft gear with a vs cam?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    ive read a couple of people saying that they cause vibrations in the motor and i dont want to hurt anything in my rebuilt engine.
    i guess a better question would be who actually has the balance shaft gear with a vs cam?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: should i get rid of my balance shaft gear with a vs cam?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    I'd remove it if your rebuilding the motor. You can just remove the drive gear or take it out completely. Taking it out requires the rear oil hole in the block to be plugged. The whole purpose of the balance shaft was to make the motor run smooth at low rpms. With a bigger cam it won't run smooth at idle anymore. I just rebuilt my motor with a similar cam and removed it
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  3. #3 Re: should i get rid of my balance shaft gear with a vs cam?
    I left mine in when i did mine but I was in a hurry to get everything together.
  4. #4 Re: should i get rid of my balance shaft gear with a vs cam?
    SWPA
    Balance shafts are put in engines for the pussified majority of the public. Its there to reduce NVH and is nothing more than another potential breaking point.
  5. #5 Re: should i get rid of my balance shaft gear with a vs cam?
    May 2008
    Schuyler, NE
    Yeah, because balance shafts break alot....
    If you are using a stock timing chain, leave your balance shaft active. It will help the motor run a lot smoother.
    The only reason it should EVER be deleted is if you are using a double roller timing chain. If not, leave it there are active.
  6. #6 Re: should i get rid of my balance shaft gear with a vs cam?
    Sep 2011
    palm harbor florida
    yeah ive got a stock timing chain.
  7. #7 Re: should i get rid of my balance shaft gear with a vs cam?
    Washington Michigan
    I would upgrade to a single roller timing chain. A double is overkill for a mild cam. doubles are for big cams and 130 lb. Springs. Btw- im guessing your upgrading to 90 or 105 springs correct? Im running an xtreme energy cam which is very close to yours and 105 springs. My motor runs real smooth other than at idle. I did have the crank (rotating assembly) balanced however. Again my balance shaft is totally removed.
  8. #8 Re: should i get rid of my balance shaft gear with a vs cam?
    Sep 2011
    palm harbor florida
    ya ive got 90# springs on the heads. the motor is 90% back together i cant put anything else on until its in the car
  9. #9 Re: should i get rid of my balance shaft gear with a vs cam?
    Washington Michigan
    90# should be ok. What did you do with the balance shaft? I doubt you'd notice a difference either way to be honest. I just took mine out because the block was going to the machine shop. That was not the initial plan lol
  10. #10 Re: should i get rid of my balance shaft gear with a vs cam?
    May 2008
    Schuyler, NE
    You'll notice the difference. My racecar still have the balance shaft, and my daily driver does not. There is a huge difference in motor vibration at idle.
  11. #11 Re: should i get rid of my balance shaft gear with a vs cam?
    Sep 2011
    palm harbor florida
    Quote Originally Posted by tms8582 View Post
    left it in. i didnt find any of this out until today. and i assembled the motor like a week ago.
  12. #12 Re: should i get rid of my balance shaft gear with a vs cam?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    you can leave it in or remove the gear.. either way the "weight" of the shaft is in there... As for breaking, I've never heard of one going out or going bad... Never heard of someone with a bad balance shaft bearing so... To each their own.. I put a double roller in my car and left the shaft in place, but removed the gear for clearance... I've driven mine on the road and at the drag strip.. no problems at all!! As for vibration, with a cam you'll have vibrations regardless due to the lope of the cam. Comp Cam's grindes for ZZP have a more aggressive lobe seperation so you'll have a slight lope with the VS. BUT I just installed poly mounts from Intense and the motor barely moves now and it's a lot better!!! If I were you I'd flip your dog bone mounts. It's a common mod regardless. Just my $.02
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  13. #13 Re: should i get rid of my balance shaft gear with a vs cam?
    Washington Michigan
    Quote Originally Posted by dbextreme View Post
    I agree I think most of the vibration people feel after installing a cam and disconnecting the balance shaft is the rough idle. I flipped the dog bones on my motor the day after getting the car lol If your installing a bigger cam it's going to idle rough period. If you want a smooth running engine go with rockers instead. Each motor on every car is going to behave slightly different because of tolerance and wear differences however.
  1. balance shaft delete?
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2013, 04:29 PM
  2. Balance Shaft Removal
    By btamayo in forum General Tech Discussion
    Last Post: 03-04-2011, 07:15 AM
  3. how do i remove the balance shaft
    By copperpacecar in forum General Tech Discussion
    Last Post: 10-07-2010, 12:59 PM
  4. balance shaft removal PLZ HELP
    By bigdawg15005 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2009, 11:58 AM
  5. Balance Shaft
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2008, 10:42 PM
