Thread: 2001 GTP (please Help) No money for mechanic
Results 1 to 13 of 13
  1. #1 2001 GTP (please Help) No money for mechanic
    May 2008
    Im having some troubles with my GTP. Hoping someone out there has had the same things happen. well driving my tach suddenly dies and my traction control light comes on. The car still drives but with no rpm. any ideas on whats wrong. Would like to thank everyone for helping me with my boost issues before. all is fixed from you advice. Thanks
  2. #2 Re: 2001 GTP (please Help) No money for mechanic
    Oklahoma
    I would almost bet my next paycheck that it is your crankshaft position sensor. Its about a $30 - 40 part but you have to pull the crank pulley to get to it. There is a write up in the How To section on how to do the work.
  3. #3 Re: 2001 GTP (please Help) No money for mechanic
    Hoffman/Schaumburg, IL
    I Agree 100% with Scotty's Diagnosis
  4. #4 Re: 2001 GTP (please Help) No money for mechanic
    Donating Users PonchoDvr4Lfe's Avatar
    Feb 2008
    Kent, OH
    X3... just for my 2 cents!!
    Someone correct me if I am wrong, but a CASE learn will also be needed after this procedure....
    04' GP GTP Comp G, 08' G8 GT, 10' Camaro 2SS
  5. #5 Re: 2001 GTP (please Help) No money for mechanic
    Oklahoma
    Not always. Ive changed mine twice now and not had to do a CASE learn
  6. #6 Re: 2001 GTP (please Help) No money for mechanic
    Donating Users chrisb's Avatar
    Bucyrus, OH
    ohh man i remember my first time getting that crank pulley bolt off had to use a 4 ft extension and a torch, i think they have locktite on the bolt? id say if you have the ability to get a case learn get it done, cause it could but not always run crappy.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  7. #7 Re: 2001 GTP (please Help) No money for mechanic
    Feb 2008
    Kent, OH
    Thank you sir...
  8. #8 Re: 2001 GTP (please Help) No money for mechanic
    Aug 2008
    SOUTH TEXAS
    I had mine changed by a mech, because u need a impact gun to remove that bolt.
    Money is tight i know, but u breaking something else trying to remove it.
    Is not worth the savings.
    Just my 2Cs worth.
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  9. #9 Re: 2001 GTP (please Help) No money for mechanic
    PA
    Sounds like a CPS to me.
    2001 GSE
  10. #10 Re: 2001 GTP (please Help) No money for mechanic
    TDCRacing
    Guest
    Quote Originally Posted by Zef_66 View Post
    No way.....
    Find someone to do it around you're house or someone knowledgable at a parts store. Usually they are pretty good and like to make some extra money...Changing a cps is something i would trust someone to do.Theres not much you could mess up doing one. <--- I hope to god no one will prove me wrong.Because that would be a shame.
  11. #11 Re: 2001 GTP (please Help) No money for mechanic
    Oklahoma
    Well lets see.
    1. Crank bolt too tight. Ambitious repair person uses 20' breaker bar to get loose and snaps off bolt in crank.
    2. Repair person has terrible day, angry at the girlfriend/wife/boyfriend/husband, full of rage and aggressively pulls off the harmonic balancer neglecting the reluctor vanes on the back side and bends one really good. Attempts to repair and snaps off.
    3. Repair person determines that he/she doesnt have the right bolt for the puller and decides to 'modify' the threads by drilling and tapping new threads. In the process the drill goes through suddenly and drills through one of the reluctor vanes and then hits wiring behind balancer chewing up the wiring harness to the cam shaft sensor.
    4. Repair person remembers trick of placing breaker bar on the bolt and trying to 'bump' the starter but doesnt know which way the pulley spins and takes a 'whack' at it since they are feeling lucky and have a 50/50 shot. They guess wrong, breaker bar swings around crashing through everything.
    5. Repair person has trouble getting crank bolt out and decides to use a little heat, sets engine bay on fire.
    Did I miss something?
  12. #12 Re: 2001 GTP (please Help) No money for mechanic
    Barksdale AFB, LA
    2009 Subaru Impreza WRX STI
  13. #13 Re: 2001 GTP (please Help) No money for mechanic
    Feb 2008
    Kent, OH
    x2, have seen all of those except the fourth one. I love having know-it-all friends for this exact purpose. Giving me something to rofl about!!!
    I don't let any of them anywhere near my car!!
  1. Saving money instead of spending on my car...
    By Quicklynx in forum Off Topic Discussion
    Last Post: 10-11-2008, 08:00 PM
  2. Need help spending some money (This should be easy)
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2008, 01:02 PM
  3. Money from the government?
    By N3p in forum The Rant Forum
    Last Post: 03-19-2008, 04:01 PM
  4. Confessions Of An Auto Mechanic
    Last Post: 03-02-2008, 01:41 AM
  5. New Mechanic
    By kburgad in forum Introductions/Noob Questions
    Last Post: 01-30-2008, 10:37 PM
