Thread: rough idle and bouncing rpm gauge
Results 1 to 13 of 13
  1. #1 rough idle and bouncing rpm gauge
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    Hello All,
    I have a 97 Grand Prix GTP with 228,000 miles, it idles rough and misfires also. I did a scan on her and these codes come up p0300 and p0441.
    When she is in park or at a light and idleing the rpm gauge bounces up, the car jerks foward and the head lights flicker. I just purchased the car about a month ago and haven't had a chance to get a tune up yet. Any help would be appreciated.
    Thanks
  2. #2 Re: rough idle and bouncing rpm gauge
    Feb 2013
    37.295091, -121.930053
    welcome p0300 and p0441 have been solved may times over on here so LOOK IT UP. and GL
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: rough idle and bouncing rpm gauge
    May 2013
    Ok thanks! I have looked up them codes and got some info on them.
    I want to know if some other members here have had this problem and if they did what was the fix. Just looking for some options.
    Thanks
    Again
    Flip
  4. #4 Re: rough idle and bouncing rpm gauge
    Start with new plugs and wires.
    If it still does it, then look into coils or the ICM, depending on which cylinder(s) is misfiring.
  5. #5 Re: rough idle and bouncing rpm gauge
    May 2013
    I will do a tune up this weekend and I will try to keep this thread updated! :-)
    Thanks for the advice friends.
    Flip
  6. #6 Re: rough idle and bouncing rpm gauge
    Feb 2013
    FFDP im guessing you made waffles
  7. #7 Re: rough idle and bouncing rpm gauge
    Flip.. to give you a little info on getting help. I got lazy one day and stopped looking up codes. These days I suggest the poster put the code number and the name of the code if they'd like some help.
    I know RMM, but which evap is 441? Help us help you.. cause these days I'm lazier or busier than I used to be and many other member have found that the "help us help you" works well.
  8. #8 Re: rough idle and bouncing rpm gauge
    May 2013
    Ok I will keep that in mind! Thanks for the advice.
  9. #9 Re: rough idle and bouncing rpm gauge
    while doing the tune up, give the throttle body a good cleaning, maf as well. These cars are notoriously simple to fix things like this.
  10. #10 Re: rough idle and bouncing rpm gauge
    May 2013
    Could this be the alternator?
    I check the alternator with a volt meter. When car is off the battery reads 12.8 volts and when its running I get14v for the first 5 minutes and it goes down to 12.8 to 13. It also does a lot of fluctuating on the volts, up and down. Also when i disconnected the positive cable on the battery it stalled. Is that normal on these cars?
    Note: While this is doing that the headlights and dash lights also get dim.
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SK® 4T65E Transmission Shift Kit, 180* Thermostat
  11. #11 Re: rough idle and bouncing rpm gauge
    May 2013
    Well, fellas and gals! It wasn't the alternator that was bad because I put a remanufactured one in there from Pep Boys and its still the same. I am going to return it and put my old one back in.
    I am thinking its the MAF sensor now. I am going to the junk yard this weekend and try to find one there.
    I will update!
    Flip
  12. #12 Re: rough idle and bouncing rpm gauge
    SE Level Member Ryan99639's Avatar
    Feb 2013
    Rockford
    I had this exact problem for like 4 months after I bought the car, I did new plugs, new wires, iac valve, coil packs, u name it Nothing solved it. Until I got a professional diagnosis from a local shop that found my intake gasket was leaking into a vacuum somewhere. So maby u have something along that line. Just trying to save u the time and money plus headache trying to find it, That's what mine was throwing the same p0300 codes too. Good luck
    BOOSTIN
  13. #13 Re: rough idle and bouncing rpm gauge
    May 2013
    I think this problem is the Fuel Pressure Regulator. What do you think?
    The hose that goes to the fpr is dry rotted and cracked at the nipple.
    Also here
    I just touched them and they cracked right off.
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Rough idle
    By GTP2188 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2012, 03:12 PM
  3. high-pitched whistle and bouncing idle
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-28-2010, 07:58 AM
  4. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
