Thread: Cleaning around the fuel injector area
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 Cleaning around the fuel injector area
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    Hello all,
    I am new here and I have a question or need some advice. Pleasebe easy on me lol.
    I have 97 grand prix gtp and the area around the fuel injectors are dirty a lot of gunk. What would be the best way to clean this area and also how?
    Thanks
    Flip
  2. #2 Re: Cleaning around the fuel injector area
    Get some purple power and a brush of some sort that will fit into the little spaces, soak the area with purple power for about 10-15 min then give it a good one over with the brush and wash it off with a garden hose. Should get rid of most of the junk. You could use a pressure washer if you wanted.
  3. #3 Re: Cleaning around the fuel injector area
    Dec 2010
    DMV
    Simple green or some degreaser. Let it sit and then wash it out with a water hose.
  4. #4 Re: Cleaning around the fuel injector area
    May 2013
    Ok sounds good. Can I use heavy duty degreaser that's in the can? For example gunk degreaser etc....
  5. #5 Re: Cleaning around the fuel injector area
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Yes you can, use degreaser, a paint brush to loosen it up a bit and if you have a air pressure hose that would work great as well.
    If You Cant Hear The Whine You're Too Far Behind...
  6. #6 Re: Cleaning around the fuel injector area
    Florida
    Use an air hose if you can, if not, use a can of air duster. I always keep one handy in the car for detailing, or if I need to pull the injectors/LIM i always use it to blow off all the sand/gunk.
  7. #7 Re: Cleaning around the fuel injector area
    St. Louis
    And before you use air or water or both to otherwise remove the grime that you have now loosened, take a second to get some safety glasses on. You really don't want that junk coming back into your eyes as you clean it off.
    Yes it sounds like common sense, but I've seen it happen far too many times.
  8. #8 Re: Cleaning around the fuel injector area
    Pennsylvania
    I'm stupid and I squint. Eye protection's a good idea.
  9. #9 Re: Cleaning around the fuel injector area
    Bathing suit can be helpful too.. Cause when the water hits that one spot on the LIM.. you are gonna get soaked.
  10. #10 Re: Cleaning around the fuel injector area
    May 2013
    I don't think this idea will work in my situation lol because it is gunked up really bad. That might be 1 of the reasons my car is running like crap.
    Thank you all for your replies!
    Flip
  11. #11 Re: Cleaning around the fuel injector area
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    sounds like your LIM gasket is leaking
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  12. #12 Re: Cleaning around the fuel injector area
    May 2013
    Quote Originally Posted by TEK310 View Post
    I was thinking the same thing! I am going to have to check on that.
    Thanks
  13. #13 Re: Cleaning around the fuel injector area
    I live here. TLSheff's Avatar
    Did you have issues with gunk pooling up in the holes and around the intake manifold like this?
    This was my 99 GTP at 75,000 miles, had a trashed Lower Intake Manifold gasket, due to previous owners lack of maintenance on the coolant. If this is the case, you will want to look between where the head and the LIM meet and see if the gasket is black or aluminum. Some cleaning would be needed, but if it's black and looks like its made of plastic, then its the old style and you will want to replace it regardless.
  14. #14 Re: Cleaning around the fuel injector area
    May 2013
    no I didn't notice none of that! Its just real gunky around the fuel injectors.
    Thanks for your reply and the pics though! good job!
  15. #15 Re: Cleaning around the fuel injector area
    SE Level Member sco77's Avatar
    MD
    Quote Originally Posted by Flip97GTP View Post
    Flip
    The outside will have no effect on the performance.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  16. #16 Re: Cleaning around the fuel injector area
    May 2013
    Well, now that I look at it a little closer it does look like this. I have those crappy plastic LIM gasket on there right now. I'm going to do a LIM gasket replacement and I'm going to use the aluminum one.
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SK® 4T65E Transmission Shift Kit, 180* Thermostat
  17. #17 Re: Cleaning around the fuel injector area
    Pooling in those area's isn't from the LIM gaskets. It's from the sealant on the bolts breaking down over time.
  18. #18 Re: Cleaning around the fuel injector area
    May 2013
    So, what do you suggest should be done, BillBoost?
  19. #19 Re: Cleaning around the fuel injector area
    Sounds like you need to do LIM gaskets anyhow. Do your lims, coolant elbows, etc etc and clean the bolts. Then use a pipe sealant with ptfe/teflon when you reassemble. That'll do the trick.
  20. #20 Re: Cleaning around the fuel injector area
    hangover park IL
    its coolant, the crankcase is not under enough pressure to force oil up the bolt threads. its coagulated dehydrated coolant. tastes like it too if you try it.
    cooling system is under pressure almost constantly, plenty to allow slow coolant creep. it can get to the point you refill the resevoir due to a mysterious "leak" you cant find...which is usually the sc tb gasket/lim gaskets.
    keep in mind what you see outside the engine is roughly 1/3rd of the coolant thats leaking, the rest is going into the intake ports on either side of the coolant passage, and into yer oil pan letting the acids eat away at your bearings (engine oil will taste bitter)
    ~James~ Psychotic Gearhead
  1. Fuel injector help !!!!
    By GTPAIELLO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2012, 06:48 AM
  2. Fuel Injector Cleaning
    By Burbman in forum General Tech Discussion
    Last Post: 12-04-2012, 11:58 AM
  3. fuel injector resistance
    By Viprklr in forum 5.3L V8 (LS4)
    Last Post: 06-17-2012, 11:48 AM
  4. fuel injector / pcm issues?
    By mastert429 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 07:43 AM
  5. Injector cleaning, yes or no?
    By Sabrewings in forum General Tech Discussion
    Last Post: 10-20-2008, 12:17 AM
