Thread: Not sure whats going on with the car (Modded)
Results 1 to 20 of 35
  1. #1 Not sure whats going on with the car (Modded)
    GT Level Member Hardonyomom's Avatar
    aurora
    https://www.youtube.com/watch?v=5T3H...ature=youtu.be
    https://www.youtube.com/watch?v=zRpc...ature=youtu.be
    Just uploaded it, help me diagnose that engine sound, is that rockers? i reopende valve covers to torque them down to 25 lbs, i have a fuel issue, i have 60s in , the driver side line leaks, Its kinked and needs to be replaced, i also have vac leak, im not sure whats going on with it.
    The other video you can hear an vacuum leak, it goes away a lil the passenger side is dripping what i thought was coolant because i thought to myself no way in the hell it can be fuel, my line is dry on passenger but its dripping. so i take it all apart and retorqued all the rockers to 25 pounds, put new coolant elbows in, got her fired up and same problems. Im kinda ticked off.
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  2. #2 Re: Not sure whats going on with the car (Modded)
    60# Injectors and stock tune!??
  3. #3 Re: Not sure whats going on with the car (Modded)
    aurora
    My buddy tuned it I believe with an overkill tune for a 3.4 on 42.5 injectors on a gen v, I have 3.4 on but i think he tuned me for 60s because he said he had to change the pulse for 60s to work.
  4. #4 Re: Not sure whats going on with the car (Modded)
    Yea that clicking is similar to what I was experiencing a few months back.. Never could figure it out before I ran out of time.
    04 Comp G.
  5. #5 Re: Not sure whats going on with the car (Modded)
    does he know a damn thing about tuning 3800s? and 60s on a tune that started out as setup for 42s? im not saying the tune is the issue and that noise def sounds like valvetrain noise but i cant tell where from when the ph9ne is next to the open cone intake. all i hear is sucking from the intake mostly
  6. #6 Re: Not sure whats going on with the car (Modded)
    aurora
    Should i start taking it apart again and take off the fuel rail and see if thats the issue? I'm about ready to just buy a 500 dollar fuel log, braided lines and be done with the fuel part
  7. #7 Re: Not sure whats going on with the car (Modded)
    aurora
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    There are two videos now. I put LS7 lifters in and i got modded rockers from greg and reusable rocker bolts, I put the pushrods in, put the lifters in according to spec, then the rockers, im not sure what we could of done wrong.
  8. #8 Re: Not sure whats going on with the car (Modded)
    dont just throw money at it youll just get more pissed sort out the noise and fix the fuel leak
  9. #9 Re: Not sure whats going on with the car (Modded)
    Yea don't throw money at it.. Yet some guys chime in first before you start going crazy with parts.
    04 Comp G.
  10. #10 Re: Not sure whats going on with the car (Modded)
    aurora
    I'm not sure how to fix the noise, I already opened it up again and torqued the rocker bolts to 25 pounds front and back covers. Is it the lifters?
  11. #11 Re: Not sure whats going on with the car (Modded)
    Was anything done to the heads? What length pushrods did you use?stock?
    04 Comp G.
  12. #12 Re: Not sure whats going on with the car (Modded)
    could try putting stock lifters in the hell with those ls7's
  13. #13 Re: Not sure whats going on with the car (Modded)
    For reference
    http://www.grandprixforums.net/threa...1-Help-w-noise!
    And that was with stock lifters, I had a set of LS7s that ended up throwing in there and noise was still there.. Ended up measuring for pushrods length and going with some 6.95 which made it slightly quieter.
    04 Comp G.
  14. #14 Re: Not sure whats going on with the car (Modded)
    aurora
    How hard is it going to be to put stock lifters in again? i think i have to take the LIM off again. if thats the case , tow this thing away
  15. #15 Re: Not sure whats going on with the car (Modded)
    It's not hard at all but will require that the lim/sc/IC comes off.. I can only imagine a shop is going to rape you on labor cost. Probably better that you do it yourself.
    04 Comp G.
  16. #16 Re: Not sure whats going on with the car (Modded)
    gardner,mass
    Sounds like you have a colapsed lifter. Did you let them soak in oil befor installing them?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  17. #17 Re: Not sure whats going on with the car (Modded)
    aurora
    No i didnt no i needed to . But i did figure out the fuel issue. I have an injector on the rear on the passenger side that is clearly pissing out fuel. what do I do from here though? Is there a way to get it to seat better without taking it apart? Its a zzp modded fuel rail. could this also be causing my other issues?
  18. #18 Re: Not sure whats going on with the car (Modded)
    this taped up evap lookin gline is your vac leak, or one of them at least.
  19. #19 Re: Not sure whats going on with the car (Modded)
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by Hardgainer View Post
    Hey Tyler sounds familiar lol? Seriously i had the same issue when you installed the injectors.. in the rails did wedge them in there? Did you check the rails before you installed them? my guess is the rails might be bent allowing the injector to not be seated in the head could you take a picture where it is leaking at?
  20. #20 Re: Not sure whats going on with the car (Modded)
    i said your car did this in the chat box and imo id take the ls7's out and put oil soaked stockers back in...........
  1. How to tell you have a modded GP
    By BillBoost37 in forum General Grand Prix Discussion
    Last Post: 05-07-2014, 12:36 AM
  2. modded 1.9rr
    By hollas13 in forum General Tech Discussion
    Last Post: 02-13-2014, 08:47 PM
  3. Modded Air Box?
    By SliceTheRice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2010, 02:18 PM
  4. GTP vs. Modded 04 STi
    By ninnyGTP in forum Track Sessions and Kills
    Last Post: 06-07-2010, 10:42 AM
  5. Modded 97 GP
    By Samson in forum Introductions/Noob Questions
    Last Post: 01-28-2010, 09:29 AM
