scan for misfires. there should be a parameter that you can watch where the misfire is according to the cylinder. if it is mainly on one cylinder then try to switch that injector to another cylinder and see if it does anything (misfires on the cylinder you put it into).
there is also a parameter to see what your IPW is. low 20s are static (open all the time) for stock injectors.
