Thread: Engine knocking after turbo build
Results 1 to 6 of 6
  1. #1 Engine knocking after turbo build
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    Before the turbo build the engine didnt make any nosies. The bottom end wasnt touched at all ( only timing chain ) , we also installed a st3 cam , heads , lifters , meziere flex plate , l26 upper intake manifold , sfi balancer , stock rockers , tep built tranny with precision industries 3000 stall converter. Started the car up and a knocking noise is coming from the bottom end. Not sure if its the flexplate hitting somthing or the converter rubbing. Theres nothing in the oil or anti freeze. I have Oil pressure.. Has anyone experienced anything like this before or know anything it might be?
    Worlds Smallest Dick Award Winner!
  2. #2 Re: Engine knocking after turbo build
    St. Louis
    Stupid question, but is the trans. full of fluid? I only ask because when I installed my used trans and at first fire up I had a knock. As soon as I got the trans full of fluid it stopped.
  3. #3 Re: Engine knocking after turbo build
    Same thing here
  4. #4 Re: Engine knocking after turbo build
    Oct 2012
    Albany, NY
    It deff got quiter
  5. #5 Re: Engine knocking after turbo build
    Jan 1970
    Maquoketa, Iowa
    How many times did you change the oil?
  6. #6 Re: Engine knocking after turbo build
    Quincy, Mass
    Can you get a vid of the noise. My TC bolts didn't go all the way in when I did mine, turned out they were a different thread size if I remember right.
    No more GP 04 Impala SS Indy:
  1. help with my turbo build please.....
    By Bino0527 in forum Turbo
    Last Post: 04-23-2013, 11:31 AM
  2. Turbo build. Run and tell that.
    By Wotgtp in forum Turbo
    Last Post: 05-25-2012, 04:08 PM
  3. Need help with my turbo build
    By Classy Pontiac in forum Turbo
    Last Post: 11-09-2011, 08:38 PM
  4. turbo build
    By Twist in forum Turbo
    Last Post: 10-13-2011, 12:30 PM
  5. Turbo build soon to come.
    By bbptech in forum Turbo
    Last Post: 03-05-2010, 09:37 AM
