You could do valve cover gaskets, the orings on the fuel injectors, I think the Fel-Pro kit comes with orings. Tb gasket usually doesn't require changing. Tstat since you should flush your coolant. Coolant elbows since the plastic ones will most likely break when removing the lim.
