Thread: Engine Issues
Results 1 to 7 of 7
  1. #1 Engine Issues
    Donating Users NHRA21's Avatar
    Clinton, Ct
    Are these engines known for breaking cranks? I ask because I just snapped mine. I broke between the #1 and #2 connecting rod journals. Also, are these interference engines? It does not look like the two halves turned on their own, but I am still worried that I could have clipped a valve.
    Thanks!
    -NHRA21
  2. #2 Re: Engine Issues
    I've only heard of a crank snapping one other time, and that was earlier this week. Which we suggested he try a different mechanic. So no..it's not common at all.
    Definately interference.
  3. #3 Re: Engine Issues
    Clinton, Ct
    Sometimes I wonder if I should try a different mechanic.....
    Guess I will be taking the heads to the machine shop along with the block to be checked. From what I can see so far, it dinged up the connecting rod at the crank, but both valves looked closed and there are no dents in the pistons. Maybe I get lucky for once. Any recommendations for a replacement crank?
  4. #4 Re: Engine Issues
    St. Louis
    Yea, a replacement longblock and call it a day. For the price of replacing the crank and all the machine work needed to keep the bottom end together it would prob. be cheaper.
  5. #5 Re: Engine Issues
    Clinton, Ct
    You don't think it would be worth having the parts checked? Everything in the lower end was already replaced two years ago. If the number one main cap is ok, I would think it would be fine.
  6. #6 Re: Engine Issues
    Clinton, Ct
    Got the rest of the engine apart. Five out of six pistons hit the valves. One bent push rod. It just keeps getting better.
  7. #7 Re: Engine Issues
    See..they are interference ... sorry for the loss
  1. engine issues,please help!
    By CountryBoy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2013, 01:16 PM
  2. Issues with the engine
    By maverickdog8 in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-24-2010, 04:23 AM
  3. Need help with a Sea-Doo, Engine Issues...
    By FastKatt in forum Off Topic Discussion
    Last Post: 07-18-2009, 01:43 PM
  4. engine issues
    By Mikel2k7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2009, 12:24 AM
  5. engine issues ??
    By sal3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2008, 06:24 PM
