Thread: L67 from 97 Buick Park Avenue Ultra into my 98 GP GT
Results 1 to 5 of 5
  1. #1 L67 from 97 Buick Park Avenue Ultra into my 98 GP GT
    Nov 2012
    West Bend, Wisconsin
    I finally found a replacement engine for my 98 GP GT.......a supercharged 3.8 from a Buick Park Avenue. Wasn't planning to go this route, but the price for the whole car was only a whopping $300, cause the tranny is toast in the Buick. Now, I know what I need to do tranny wise to hook up to my non HD. My question is, what parts are relatively easy to replace for preventative maintenance in a L67? Thinking all gaskets, crank position sensor, larger Mallory wires around 10 mm or so, plugs, etc. I have a SD stainless steel header set that will be going on while the engine is out. Might do a the cam too. Still need to read/search further. Both cars are untouched at this point, nmd I am trying to get all of my research and parts ready.
  2. #2 Re: L67 from 97 Buick Park Avenue Ultra into my 98 GP GT
    http://www.grandprixforums.net/super...-gt-77881.html
  3. #3 Re: L67 from 97 Buick Park Avenue Ultra into my 98 GP GT
    gardner,mass
    ^lol^
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: L67 from 97 Buick Park Avenue Ultra into my 98 GP GT
    Nov 2012
    Yeah, that thread was to see if the Park Avenue Ultra motor would work into my NA 98 GP GT Turned into discussion on EGR delete and my headers/exhaust. Bought the Park Avenue Ultra. Now, trying to find out what should be replaced that is supercharger specific? And do I need to change anything in regards to my stock fuel system being a non supercharged car?
  5. #5 Re: L67 from 97 Buick Park Avenue Ultra into my 98 GP GT
    Swap:
    Rear exhaust manifold
    Flex plate
    Remove PA motor mount and put bolt that plugs hole (above WP near coil pack) from old motor into the new one.
    Oil filter adapter
    PA oil pressure sensor for GP oil switch
    Add GP lower motor mount to PA motor
    Add GP upper driverside mount to PA motor
    Change coil pack bracket to GP mount/bracket
    Confrim alternator bracket is the same.
    Solder the map connector onto the GP harness (wire colors match up to old sensor)
    Figure out how you want the fuel lines to connect.
    Drop it in and connect it up.
    Have pcm programmed for the changes.
  1. Supercharged 97 Buick Park Avenue Ultra 3.8 into a 98 GP GT
    By BackwoodsEngineering in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2013, 07:57 PM
  2. 2000 Park Avenue Ultra sway bar size?
    By buickman104 in forum General Tech Discussion
    Last Post: 04-02-2012, 04:37 PM
  3. Stupid Question: Can Park Avenue go in GP?
    By brandonl2000 in forum General Tech Discussion
    Last Post: 10-19-2010, 12:41 PM
  4. Changing belt on 1997 Buick Park Avenue Ultra
    By joshua_arndt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2010, 12:39 AM
