Swap:
Rear exhaust manifold
Flex plate
Remove PA motor mount and put bolt that plugs hole (above WP near coil pack) from old motor into the new one.
Oil filter adapter
PA oil pressure sensor for GP oil switch
Add GP lower motor mount to PA motor
Add GP upper driverside mount to PA motor
Change coil pack bracket to GP mount/bracket
Confrim alternator bracket is the same.
Solder the map connector onto the GP harness (wire colors match up to old sensor)
Figure out how you want the fuel lines to connect.
Drop it in and connect it up.
Have pcm programmed for the changes.
