Thread: 3K+ RPM at start up?!??
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: 3K+ RPM at start up?!??
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Alright..... looks like I have to do it again, blast!
    '04 MC Intimidator SS,'96 Camaro Z28 ,'98 GTP 12.9 trap
    '93 383 stroked Trans am (Crashed),
    '93 Chevy c1500 Pickup Indy500 Special edition,
    '01 VW GTI Garrett 50 trim, '98 GTX clone (Current car) Working on Top swap!
  2. #22 Re: 3K+ RPM at start up?!??
    Round lake, IL
    Thank you for all the help
  3. #23 Re: 3K+ RPM at start up?!??
    NP.. I hope you diagnose it before you pull it apart.
  4. #24 Re: 3K+ RPM at start up?!??
    Round lake, IL
    I will, but if you say the RTV will not suffice with the cut gasket I might as well re do it
  5. #25 Re: 3K+ RPM at start up?!??
    that's only if the cut is leaving you a big leak. If it's not causing the leak, then even a new gasket won't fix what isn't broken. Locate the issue. I'm merely suggesting where I've commonly seen them.
  6. #26 Re: 3K+ RPM at start up?!??
    Round lake, IL
    Gotcha, any other ideas besides that?
  7. #27 Re: 3K+ RPM at start up?!??
    Round lake, IL
    SO checklist for today, check IAC, TB cables and check for vacuum leaks, hopefully I don't have to replace the SC gasket again, but it looks like I might have to anyways
  8. #28 Re: 3K+ RPM at start up?!??
    Round lake, IL
    UPDATE: made a new SC gasket.... RPM's dropped a bit to about 2.5K, still same issue, I don't really know how to diagnose a IAC issue
  9. #29 Re: 3K+ RPM at start up?!??
    Round lake, IL
    Update, codes are P0442, p1336,p1176, getting horrible gas mileage (10MPGs), still have the idle issue, in park at 2Kish or so, driving 1300 RPM, stays at a steady 40 MPH =(
  10. #30 Re: 3K+ RPM at start up?!??
    Please list the names for your codss...
    I see something evap and something crank ..
  11. #31 Re: 3K+ RPM at start up?!??
    Round lake, IL
    OBD-II Trouble Code: P0442 Evaporative Emission Control System Leak Detected (small leak)
    P1336 Crankshaft Position (CKP) System Variation Not Learned
    1176 o2 sensor slow response bank 1
  12. #32 Re: 3K+ RPM at start up?!??
    Found it
    P1176 - O2 Sensor Slow Response Bank 1
  13. #33 Re: 3K+ RPM at start up?!??
    Round lake, IL
    Yep that's the one
  14. #34 Re: 3K+ RPM at start up?!??
    Round lake, IL
    What should I do? Or be looking for?
  15. #35 Re: 3K+ RPM at start up?!??
    Round lake, IL
    Any ideas?
  16. #36 Re: 3K+ RPM at start up?!??
    Round lake, IL
    Anyone?
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. No Start :(
    By Curt7 in forum General Tech Discussion
    Last Post: 10-15-2012, 12:49 PM
  3. Are you ever to old to start having fun again...?
    By JustanAlias in forum Introductions/Noob Questions
    Last Post: 05-14-2012, 02:58 PM
  4. where to start
    By bitterpill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 10:46 PM
  5. no start
    By betsgtp in forum General Tech Discussion
    Last Post: 06-05-2009, 12:19 AM
