Thread: 03 Top Swap running hot UP AND RUNNING
Results 1 to 20 of 36
  1. #1 03 Top Swap running hot UP AND RUNNING
    Dec 2008
    Lawndale, CA
    For the past couple of weeks my brothers 03 top swap has been running hot. The temp gauge would get to the 210 mark and not go any lower than about 200. His aeroforce was also reading at around 200. The fans do turn on but the temperature does not drop to normal. Same thing when driving on the highway on his way to work. The temperature would stay around 200 and not drop (about a 30 mile commute). He did have to add coolant every few days as coolant was leaking internally somewhere. The car had been running fine after the top swap.
    Here are some things that have been done:
    Bled the system and there was no air in the system
    Replaced the 180 T-stat with a 195
    Replaced the waterpump
    Replaced the radiator cap
    Replaced the duralast ECT sensor with a delco
    Removed the LIM and double checked the aluminum LIM gaskets (they were ok). During this time we did notice that the oil was milky on the oil cap.
    We didn't go any lower into the heads to make sure the gaskets are ok or if the heads are ok.
    Even after all of these changes the car is still running hot.
    I'm looking for more ideas to figure this thing out.
  2. #2 Re: 03 Top Swap running hot
    HUDSON
    200 is not hot, 200 is not even boiling. 210 is not hot either. As long as coolant and pressure are maintained, 230 is starting to get hot. If there is a large inconsistancy in the temperature during operation, I would say there is a problem.
  3. #3 Re: 03 Top Swap running hot
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by QUICKSILVER462 View Post
    Although that is true. The car should drop in temperature when driving on a long stretch of highway with the cooler air coming in. The temperature should be about the same as my 99.
    If the oil is milky you might have a bad head or gasket.
    I'm starting to lean to either one of these as being the problem.
  4. #4 Re: 03 Top Swap running hot
  5. #5 Re: 03 Top Swap running hot
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Did you use felpro head gaskets?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  6. #6 Re: 03 Top Swap running hot
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by BlackGT97 View Post
    Yeah we did. I have his car this week since my commute to work is short and it's still eating coolant. It will be coming apart again to inspect the gaskets and the heads.
  7. #7 Re: 03 Top Swap running hot
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    i would think his top swap would make a bit more heat then your gt
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  8. #8 Re: 03 Top Swap running hot
    Pennsylvania
    Quote Originally Posted by Seachicken View Post
    Yer makin' that up.
  9. #9 Re: 03 Top Swap running hot
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by SlowNA06 View Post
    Yer makin' that up.
  10. #10 Re: 03 Top Swap running hot
    I'm confused by the contradiction of your statements.
    The car is running hot at 200 while driving on the highway. I put in a 195F thermostat.
    195F will open around 195F to an engine, that's very close to 200F. Running at 210F isn't very hot if you have stock fan settings.
    The oil is milky, it is leaking coolant internally. We don't know what the issue is.
    If you are using coolant internally, you have a serious problem that needs to be addressed ASAP. That is ..if your milky oil wasn't caused by a little coolant in the oil from doing the heads. Keep in mind the steel oil pan on most of these motors will hold 3/8" of lfuid below the drain plug. How much coolant is it going through? Is the engine burning coolant, you can tell by the exhaust.
    Tell us more about the top swap. Parts you used for gaskets, if you sprayed the HG's with copper spray, if you used ARP bolts or stockers, or reused.
  11. #11 Re: 03 Top Swap running hot
    Dec 2008
    Lawndale, CA
    The car was even running hot with the 180 t-stat. The fan settings are set to 185. It just sits at around 210 all day regardless. If I remember correctly my brother did say that there were a couple times that it did exceed that temperature.
    It is possible that a little coolant got in. Anything is possible. But when we did the swap we changed the oil and put clean new oil in after a few hundred miles. When we took some of it apart last weekend there was milky oil on the oil cap. I didn't take the valve covers off. But everything was cleaned prior to installing parts. I can't really tell from the exhaust but I will double check. Regardless it's coming apart starting this weekend for inspection.
    The LIM gaskets were GM aluminum and the head gaskets were felpro. As far as bolts they are stockers and I am not sure if my bro sprayed copper spray on them. He had the heads on by the time I got home but for now until I ask him I'm going to say no that it was not used.
  12. #12 Re: 03 Top Swap running hot
    New stock bolts or did you reuse them?
  13. #13 Re: 03 Top Swap running hot
    Dec 2008
    Lawndale, CA
    A little update. Finally pulled off the heads and found this on the front one. The gasket appears to have failed on the center and on the left as well. The rear gasket was fine. The heads themselves look ok but we will be getting a second opinion from a shop. There was definitely coolant and oil mixing in the LIM and the heads. Also removed some of the carbon build up from the center.
  14. #14 Re: 03 Top Swap running hot
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Damn I bought felpro head gaskets for my top swap. I'm also using ARP head studs though. Sucks for the luck. Hopefully it's just a matter of replacing gaskets and you're back on your way.
  15. #15 Re: 03 Top Swap running hot
    Dec 2008
    Lawndale, CA
    Just got word from the machinist at the shop. One head was cracked and the other was fine. I forgot to mark the bad one to see if that was the issue. He is going to see if he can fix it. If not then a replacement would be needed.
  16. #16 Re: 03 Top Swap running hot
    Sep 2012
    North Carolina
    I have an extra L67 head. There's an exhaust stud broken off in it though.
  17. #17 Re: 03 Top Swap running hot
    If it cracked between the valves like 90% of all 3800 heads, then just bolt it down and run it.
  18. #18 Re: 03 Top Swap running hot
    Dec 2012
    wichita,ks
    I don't know GM'a 3.8 sc motors but I know my head on my super coupe thunderbird was like this and I lost compression because of it..
    It is just a FAMILY CAR
  19. #19 Re: 03 Top Swap running hot
    Dec 2008
    Lawndale, CA
    They are in the process of fixing the bad one. Should have it by monday.
  20. #20 Re: 03 Top Swap running hot
    Jersey
    Quote Originally Posted by mudneck4 View Post
    No, 97 gtps heads are known for small hairline cracks in between the valves
  1. Running PCV on gen V swap L67?
    By sseigtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2012, 09:52 AM
  2. L67 swap not running right
    By thunder71173 in forum General Tech Discussion
    Last Post: 04-23-2011, 07:44 PM
  3. Top swap NOT running right.
    By Pure2sin in forum Engine
    Last Post: 12-10-2010, 10:01 PM
  4. well, got the car running after swap, but....
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 07:17 PM
  5. Swap= not running, misfire
    By nxgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2010, 02:11 PM
