Thread: Coolant leak revisited
Results 1 to 3 of 3
  1. #1 Coolant leak revisited
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    So last weekend my water pump started leaking, I got that replaced and thought I had the leak fixed. Now, it's still leaking from somewhere. The coolant is pooling up and leaking from underneath the lower motor mount I believe it is. The water pump was definitely the original problem, but now I have no idea where this leak is coming from
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  2. #2 Re: Coolant leak revisited
    So we gotta start totally over with a new thread?
  3. #3 Re: Coolant leak revisited
    If you can't find the answer in this thread as to where the possible leak areas are.. I dunno how to help further.
    http://www.grandprixforums.net/coola...ank-77545.html
  1. Coolant leak NEED HELP!
    By nickskip08 in forum Introductions/Noob Questions
    Last Post: 01-03-2013, 10:05 AM
  2. Coolant leak
    By Cummins97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-15-2012, 08:06 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Coolant Leak, But Where??
    By brandonl2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2011, 10:46 PM
  5. Coolant Leak
    By rippemblue2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2010, 11:30 AM
