If you are going off of pure power or intake sound, then all engines put out slightly less power when hot, especially boosted ones, that's one reason for trying to keep the intake temperatures as low as possible.
Other possibilities are a vacuum or exhaust leak, the expansion from heat can make certain leaks worse after an engine is hot, especially around EGR and manifolds.
