well, if the problem started after doing the gaskets then you may have something going on with that--assuming the car ran fine before. like maybe a vacuum is leaking somewhere. after pulling those apart doing the intake they are so old they crack and stuff. not just the lines but the rubber boots and stuff.
if not and its always run like garbage its probably the plugs.
