Thread: Couple questions regarding build in progress
Results 1 to 9 of 9
crbquist Couple questions regarding... 04-21-2013, 08:52 PM
QUICKSILVER462 Re: Couple questions... 04-21-2013, 09:26 PM
GTPpower Re: Couple questions... 04-21-2013, 11:48 PM
crbquist Re: Couple questions... 04-22-2013, 12:16 AM
BillBoost37 Re: Couple questions... 04-22-2013, 05:32 AM
crbquist Re: Couple questions... 04-22-2013, 08:51 AM
BillBoost37 Re: Couple questions... 04-22-2013, 09:11 AM
crbquist Re: Couple questions... 04-22-2013, 09:22 AM
BillBoost37 Re: Couple questions... 04-22-2013, 11:03 AM
  1. #1 Couple questions regarding build in progress
    GTX Level Member crbquist's Avatar
    Massachusetts
    I'm in the process of swapping heads and installing an IC and have a couple questions..
    First, is it really necessary to copper spray fel-pro head gaskets? If so, then what is the correct procedure - how many coats per side? How long do I let the gaskets hang after spraying before laying them on the block?
    Second? What is the typical rocker arm bolt torque spec? I have heard 15, 25, 28, and 30 ft lbs. I would assume it is either 28 or 30..
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #2 Re: Couple questions regarding build in progress
    HUDSON
    For the head gaskets, follow the instruction that came in the package of the gaskets, if it says "install dry" then do just that, the lt.blue gaskets I spray two coats and let stand 5-10 min. then install and torque to spec. For the FELPRO PERMA TORQUE, I have always installed dry. Most important is a clean and dry block and head surface.
  3. #3 Re: Couple questions regarding build in progress
    May 2008
    Schuyler, NE
    For fel-pro's, you don't need copper spray. Just make sure your block and head surfaces are very very clean.
    What rocker bolts are you using? Stock, or ARP, etc?
  4. #4 Re: Couple questions regarding build in progress
    Massachusetts
    Reusable rocker bolts from zzp
  5. #5 Re: Couple questions regarding build in progress
    25ft lbs on reusables.
    On HG's, yup, what they said.
  6. #6 Re: Couple questions regarding build in progress
    Massachusetts
    Thanks everyone!
  7. #7 Re: Couple questions regarding build in progress
    Forgot to mention.
    After you torque down the rockers, roll the motor over and retorque a couple of times. Reason behind it is technically you should torque the bolts with that cylinder at TDC. Since no one does.. you want to make sure you got the torque correct by rechecking a few times after moving the assembly.
  8. #8 Re: Couple questions regarding build in progress
    Massachusetts
    Forgot to mention.
    Ok cool. That's the same thing I did when I did my mustang build years ago now that I remember haha. So just roll it via the balancer using a torque wrench or something, correct?
  9. #9 Re: Couple questions regarding build in progress
    Yes sir
  1. VS Build almost done just a couple of questions..
    By GTP89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2013, 01:53 PM
  2. build progress...finally
    By Dan71 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2011, 11:49 AM
  3. Progress over the past year on the GTP / IC Build Pictures
    By intrigue98 in forum Members Rides
    Last Post: 07-18-2011, 11:16 AM
  4. My Build progress 56k no way
    By ChrisGTT in forum Turbo
    Last Post: 02-05-2009, 11:35 PM
  5. build in progress
    By sra_chipmunk in forum Off Topic Discussion
    Last Post: 06-11-2008, 07:09 PM
