Thread: 99GTP oil smell/leak
Results 1 to 7 of 7
  1. #1 99GTP oil smell/leak
    Apr 2013
    Ohio
    I just bought a 99 GTP from a retired original owner. It is in very good shape. I have had it a couple weeks and have noticed a slight burning oil smell after driving it. Today was the first time I have put a lot of miles on it (100 or so) and I noticed some oil on the garage floor. The car has only had about 10000 miles out on it since 2007 so I am worried about dried or cracked gaskets. I don't notice anything out of he ordinary when I drive it. It has never had the intake manifold gaskets done. They are still black, not silver. What are your thoughts?
  2. #2 Re: 99GTP oil smell/leak
    antioch ill
    probally the front valve cover gasket
  3. #3 Re: 99GTP oil smell/leak
    I would look at valve covers and the oil pan gasket.
    Valve cover leak can cause the oil to hit the manifolds and start the car on fire and you don't want that.
  4. #4 Re: 99GTP oil smell/leak
    Grand Rapids, MI
    probably the front valve cover leaking onto the exhaust mani, but as for the oil on the ground I would point to the oil pan gasket, those are notorious as well.
    get those lim gaskets done and you ought to have a solid babied car.
  5. #5 Re: 99GTP oil smell/leak
    Apr 2013
    Ohio
    What's a good ballpark estimate for those jobs? I know the parts are cheap. I could probably tackle it but honestly don't have the time. I've got a guy that is retired from GM that has a small shop. He's usually about half of dealer costs and I've never had an issue with his work. I may just have him do it. Just not sure what to expect as far as price though.
  6. #6 Re: 99GTP oil smell/leak
    Apr 2011
    Elk Rapids, Michigan
    Check the oil pressure switch that's by the oil filter. It is a common problem. It can leak through the connector and leak on the ground on the passenger side. My valve cover gaskets also caused the burning oil smell. Change them for sure.
  7. #7 Re: 99GTP oil smell/leak
    If you smell it, it's valve covers. If you see it after a long drive, it's valve covers.
    Labor to swap the covers is 1.5 in the book. It'll take someone on the ball about an hour.
  1. Oil leak and coolant smell
    By littlerobinson75 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2012, 05:33 AM
  2. swapping l32 into 99gtp
    By nyls1346 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2011, 12:29 PM
  3. I smell coolant but can't find a leak 01 GP GTP
    By smooth01gtp in forum Introductions/Noob Questions
    Last Post: 02-16-2010, 07:06 AM
  4. 99GTP vs. 02 Audi TT
    By Bogers99GTP in forum Track Sessions and Kills
    Last Post: 06-30-2008, 11:26 AM
