Thread: Check Engine Light on 2004 GTP Comp G
Results 1 to 5 of 5
  1. #1 Check Engine Light on 2004 GTP Comp G
    Mar 2013
    Burton,MI
    A couple days ago i put a lower temp thermostat in my 2004 GTP Comp G.( down to 160) Then a couple days later the check engine light came on, so i went to autozone to pull up the code and it say coolant temp too low and the check engine light is still on. Is there a way to get rid othe chexk engine light permanently? Without having to disconnect to ground all the time. I am selling this car!
  2. #2 Re: Check Engine Light on 2004 GTP Comp G
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    completely stock GTP? ....if it's not tuned for it, there's really no benefit.....
  3. #3 Re: Check Engine Light on 2004 GTP Comp G
    Mar 2013
    Burton,MI
    The old thermostat i didnt feel kick on soon enough so i got the lower temp on
  4. #4 Re: Check Engine Light on 2004 GTP Comp G
    Sep 2012
    Quote Originally Posted by daltman360 View Post
    it won't do anything unless tuned for it....and 160 on a stock GTP is too cold....
  5. #5 Re: Check Engine Light on 2004 GTP Comp G
    Car is very inefficent when running that cold, what you think is too warm is actually what the car loves.
    There is no need to ever run a colder thermostat while stock. Gas mileage and overall performance will go down when the motor runs too cold and like you noticed its sets the check engine light off.
  1. 2004 gtp comp g engine shut off issues
    By jgomori in forum Introductions/Noob Questions
    Last Post: 05-23-2012, 07:20 PM
  2. Check engine light
    By 0GTP4 in forum General Tech Discussion
    Last Post: 02-11-2012, 11:24 AM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  5. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 09-01-2008, 09:01 PM
