Thread: what is required for a gen 5 blower swap?
Results 1 to 4 of 4
  1. #1 Re: what is required for a gen 5 blower swap?
    Wichita, KS
    ^What he said plus...
    *GenV specific gasket
    *new or modified stock throttle/cruise control cable bracket
    *the longer bolts the GenV needs
    (if you have a IC add what ever thickness to the length of the bolts)
    *a vacuum tube to correctly connect the PVC system from the back of the SC to the intake
    *a black off plate for the EGR on the back of the supercharger
    (I custom made these out of aluminum or carbon fiber FYI)
    You don't really need the GenV LIM, if you know a local machine shop, bring them in your stock genIII LIM and the GenV SC gasket and sit the gasket on the LIM and show them the extra meet int he inlet of the LIM that needs to be cut out. about a 10 minute job with a Bridgeport, and usually runs around $10.00 cash.
    ~F~
  2. #2 Re: what is required for a gen 5 blower swap?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    If your going for a Gen V get a N* or LS1 TB to go along with it.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  1. Premium fuel required!?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2012, 10:20 AM
  2. tire pressure monitoing rim sensor info required
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 01-16-2009, 08:56 AM
