Thread: Poor Performance and RPM climb following LIM install
Results 1 to 5 of 5
  1. #1 Poor Performance and RPM climb following LIM install
    Smithville, MO
    Hi All,
    I'm looking for suggestions to fix my '99 GTP from the following conditions...
    I just replaced the LIM along with, valve cover gaskets, plugs and wires. Other than running it around the neighorhood the get up to temperature and check for leaks, this mornings trip to work (40 miles) was the first real test. She ran like a champ for the first 30 miles, but after a slight increase in speed to change lanes the boost gauge on the info center showed about 1/3. At that point I did not notice a change in performance. within a couple of miles the boost indicator moved up to 2/3 and I noticed a hesitation and lack of throttle response. For the next 8 miles the rpms climed to almost 4k, the average mpg went from 32.8 to 16 and it really stumbled upon stops. I limped to work and checked for leaks - nothing obvious.
    I think I hear a vacuum leak somewhere, but it's hard to tell with the K&N intake noise at the elevated rpms. This LIM was the most aggresive repair I've ever attempted, but the oil smoke/smell had me convinced that my car would be a charcoal briquette if it was not fixed. The only difficulte I had (or think I had) was the routing of all the wires upon reassembly.
    There are no dummy lights on and the temperature fine throught the trip this morning.
    Any help would be appreciated. I'm not looking forward to the trip home tonight.
    Thank you,
    Joe
  2. #2 Re: Poor Performance and RPM climb following LIM install
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Most common spot to leak is on the LIM itself. Look just below the S/C snout and make sure your vacuum line connection to the LIM is good. There may also be a coupler there... spray test all connections.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  3. #3 Re: Poor Performance and RPM climb following LIM install
    Smithville, MO
    Just ran out during lunch and found a vacuum line that was not attached. It was part of the line that came from the front of the S/C, "T"ed off into the LIM under the snout and went around to the back of the S/C. The problem is I don't see a place to seat it.
    Does anyone know want this vacuum line terminates to on the backside of the S/C?
    Thanks again,
    Joe
  4. #4 Re: Poor Performance and RPM climb following LIM install
    It goes into the map sensor.
  5. #5 Re: Poor Performance and RPM climb following LIM install
    Smithville, MO
    Found it.
    I found the attachment pont - bottom side of the MAP sensor. She idles fine now, run up the street with full power again and hopefully the trip home will be uneventful.
    Thanks to slick2500 and all the contributors on this site.
    Joe
  1. performance module install( HELP ME )
    By gp 98 gtp in forum Introductions/Noob Questions
    Last Post: 08-04-2011, 04:04 PM
  2. Poor car...
    By iceman977th in forum Off Topic Discussion
    Last Post: 12-21-2010, 12:20 PM
  3. performance shift install
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2010, 12:54 PM
  4. P0121 & poor performance after dyno tune
    By nugzo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2009, 04:11 PM
  5. Poor mpg! Help
    By rocafella2032 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2009, 08:15 PM
