Thread: Upgrade pushrods? Ye or Ne?
Results 1 to 13 of 13
crbquist Upgrade pushrods? Ye or Ne? 04-09-2013, 08:31 AM
BillBoost37 Re: Upgrade pushrods? Ye or... 04-09-2013, 08:33 AM
crbquist Re: Upgrade pushrods? Ye or... 04-09-2013, 08:35 AM
BillBoost37 Re: Upgrade pushrods? Ye or... 04-09-2013, 08:39 AM
crbquist Re: Upgrade pushrods? Ye or... 04-09-2013, 08:45 AM
BillBoost37 Re: Upgrade pushrods? Ye or... 04-09-2013, 09:37 AM
crbquist Re: Upgrade pushrods? Ye or... 04-09-2013, 09:46 AM
BillBoost37 Re: Upgrade pushrods? Ye or... 04-09-2013, 09:51 AM
crbquist Re: Upgrade pushrods? Ye or... 04-09-2013, 09:54 AM
GTPpower Re: Upgrade pushrods? Ye or... 04-09-2013, 12:39 PM
crbquist Re: Upgrade pushrods? Ye or... 04-09-2013, 02:09 PM
GTPpower Re: Upgrade pushrods? Ye or... 04-09-2013, 04:01 PM
crbquist Re: Upgrade pushrods? Ye or... 04-09-2013, 04:49 PM
  1. #1 Upgrade pushrods? Ye or Ne?
    GTX Level Member crbquist's Avatar
    Massachusetts
    I'm hopefully going to be doing a ported heads and IC install in a couple weeks. With that said I was thinking this would be the ideal time to replace my 112k stock pushrods. Should I buy some heavy duty ones, replacement stockers, or simply keep running my originals? Not sure if its quite necessary, or if just one of those "why not?"s since it will be all apart anyway.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #2 Re: Upgrade pushrods? Ye or Ne?
    Which springs do you plan on running?
  3. #3 Re: Upgrade pushrods? Ye or Ne?
    Massachusetts
    Crow 105's with titanium retainers are already installed on my new heads
  4. #4 Re: Upgrade pushrods? Ye or Ne?
    From a strength perspective, stock or stock replacements should work w/o issues.
    Knowing how well you take care of the car, I would assume your stock are still perfectly fine. With that said, it's up to if you want to change them. There's no reason I can think of that would lead you to change them.
  5. #5 Re: Upgrade pushrods? Ye or Ne?
    Massachusetts
    I was thinking of the long run. The motor has 112k and is almost 13 years old. It's also been over 5k miles since you did my cam swap. All is well, I just figured with the additional mods and pushing the motor well over 300whp it would be ideal to freshen the vavle train up a bit.
  6. #6 Re: Upgrade pushrods? Ye or Ne?
    It wouldn't hurt. Do you plan on changing out the rockers at the same time?
  7. #7 Re: Upgrade pushrods? Ye or Ne?
    Massachusetts
    Nah, aren't stock rockers the best to run?
  8. #8 Re: Upgrade pushrods? Ye or Ne?
    Yes, my thoughts was if you are aiming to replace a rod based on miles/wear etc, it seems to me that you would be thinking about the bearings in the rockers as well.
    Not that either should be a concern at your mileage. A pushrod in a good motor shouldn't have wear and tear. I could see more of a case for replacing rockers based on mileage/bearings etc.
  9. #9 Re: Upgrade pushrods? Ye or Ne?
    Massachusetts
    Hmmm never looked at the rockers that way.. Maybe I will replace them as well since it will be apart. Time to check out rock auto.
  10. #10 Re: Upgrade pushrods? Ye or Ne?
    May 2008
    Schuyler, NE
    I would just reuse everything. 112k is nothing on these motors.
  11. #11 Re: Upgrade pushrods? Ye or Ne?
    Massachusetts
    So I should be good to at least 200k with the factory valve train components?
  12. #12 Re: Upgrade pushrods? Ye or Ne?
    May 2008
    Schuyler, NE
    Springs will obviously wear out depending on what you are running. I've never seen a stock style rocker arm or pushrod wear out though.
  13. #13 Re: Upgrade pushrods? Ye or Ne?
    Massachusetts
    I guess I'll probably just run the stockers then.
  1. Lightweight Pushrods?
    By GMR Badass in forum General Tech Discussion
    Last Post: 02-20-2013, 06:04 PM
  2. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  3. pushrods
    By Stock4now in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-26-2011, 05:33 PM
  4. Can I run stock pushrods with H.S. 1.9 RR's?
    By jlturbos in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2010, 03:42 PM
