Thread: 3800 Problem
Results 1 to 14 of 14
  1. #1 3800 Problem
    GTP Level Member GrandPrixgtp2000's Avatar
    Madrid Iowa
    After I put my headers and pulley on last weekend I took my car out and I went WOT and my rpm went to 4000 and just bounced their until I let off a little bit then it went normal, so I put a new fuel pump in tonight and took it out did a burnout went fine then when I got to 2nd gear it did the same thing, anybody know what the problem could be and also what is the fuel psi suppose to be at because I when I checked it, it was at about 46psi on the new pump and the old one held about 39-41psi! Any help to this problem would be appreciated!
  2. #2 Re: 3800 Problem
    Kansas
    Let me guess... you are not actively scanning parameters on the car?
  3. #3 Re: 3800 Problem
    Madrid Iowa
    Negitive, not yet
  4. #4 Re: 3800 Problem
    St. Louis
    It sounds like your burnouts may have sent this tranny on it's way to a slow death. These cars don't like burnouts/abuse in stock form.
    And yea, before you go beating on it please scan it and make sure your next post isn't about a chipped piston
  5. #5 Re: 3800 Problem
    Please give us more info.
    Year
    Mileage
    Model
    any other history etc that you think we might ask.
  6. #6 Re: 3800 Problem
    Madrid Iowa
    1999 Pontiac Grand Prix GTP 3800 Series 2 Supercharged, 182,520 Miles 3.6 zzp pulley, speed daddy headers
  7. #7 Re: 3800 Problem
    Sorry ...lack of caffination caused me to now see the sig. How long have those msd's been on. They have been known to break down and cause issues at higher rpm. Usually when they are less than a year old.
  8. #8 Re: 3800 Problem
    Madrid Iowa
    Its ok lol... the msd's have been on for about 10 months do you think it might need new ones and it it does should i go GM coil packs?
  9. #9 Re: 3800 Problem
    Ohio
    Put your stock coil packs back on and see if you notice a difference.
  10. #10 Re: 3800 Problem
    Madrid Iowa
    the stock ones were bad, when i first got the car i took it out and went wot and it did almost the same thing but with the stock ones the ses came on
  11. #11 Re: 3800 Problem
    Ohio
    Ahh. Time to make a junkyard trip then
  12. #12 Re: 3800 Problem
    Madrid Iowa
    im thinking so I will probably pick up a new fuel filter as well
  13. #13 Re: 3800 Problem
    Ohio
    Couldn't hurt. Start spraying the fittings with pb blaster now.
    And remember, twist the filter, not the line.
  14. #14 Re: 3800 Problem
    Madrid Iowa
    Got it thanks for the help hope it works
  1. Is the intake gasket a problem on 2004 & newer 3800?
    By mntnbiker in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-15-2013, 02:33 PM
  2. The Common Stall Start Problem 3800 N/A Series II
    By 94GrandPrixSE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2012, 09:08 PM
  3. My 97 GTP's Overheating Problem (3800 V6) - Solved !
    By Mrs Goodwrench in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2010, 10:27 PM
  4. 98 3800 GT to Supercharged 3800 ?'s
    By jsavi85 in forum General Tech Discussion
    Last Post: 07-28-2010, 07:43 AM
  5. 3800 vs 3800 Supercharged
    By extreme in forum General Tech Discussion
    Last Post: 07-31-2009, 10:45 PM
