Thread: 7 codes.....yay....not... HELP!
Results 1 to 9 of 9
  1. #1 7 codes.....yay....not... HELP!
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Hey guys, having some issues here, your help is always appreciated. Replaced the rear o2, whole TB including the sensors....
    I have the following
    (these codes appeared after the swap)
    p0713
    p1571
    P0443
    p0141
    p0135
    p0125
    p0102
    Any ideas guys?
    '04 MC Intimidator SS,'96 Camaro Z28 ,'98 GTP 12.9 trap
    '93 383 stroked Trans am (Crashed),
    '93 Chevy c1500 Pickup Indy500 Special edition,
    '01 VW GTI Garrett 50 trim, '98 GTX clone (Current car) Working on Top swap!
  2. #2 Re: 7 codes.....yay....not... HELP!
    what did you swap from? then into?, year of car all that good stuff. not sure what to pick in the sig lolDTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input 5 you change the trans too?
    p1571 abs problems. hub or wires maybe.
    OBD-II Trouble Code: P0443 Evaporative Emission Control System Purge Control Valve Circuit what engine did you swap to? you cange the evap.or forget to hook it up?
    OBD-II Trouble Code: P0141 Oxygen O2 Sensor Heater Circuit Malfunction (Bank1, Sensor2) checked the o2 wires?
    OBD-II Trouble Code: P0135 Oxygen O2 Sensor Heater Circuit Malfunction (Bank1, Sensor1) same thing really, as above it seems.
    OBD-II Trouble Code: P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control temp sensor, it it plugged in? its under the t stat in the lim.
    OBD-II Trouble Code: P0102 Mass Air Flow (MAF) Circuit Low Input and a good old maf code. clean the maf, check the wires, or maybe its dead.
  3. #3 Re: 7 codes.....yay....not... HELP!
    Round lake, IL
    Sorry its a 99 GTP, stock minus an intake, I replaced the whole TB and rear o2 that is it.
  4. #4 Re: 7 codes.....yay....not... HELP!
    what codes did you start out with? why did you change the TB?
  5. #5 Re: 7 codes.....yay....not... HELP!
    Round lake, IL
    Just the rear o2 code, I can't remember what it was, missfire, 500 RMP idle, running very rich (13 MPG) also lights dim bad when I go in reverse
  6. #6 Re: 7 codes.....yay....not... HELP!
    this looks like a post for Mr boost lol its a rough one for sure. im at at a loss here. unless all that stuff just went bad at once. seems unlikely.
  7. #7 Re: 7 codes.....yay....not... HELP!
    Did you replace it with a 99-03 tb?
  8. #8 Re: 7 codes.....yay....not... HELP!
    Having so many codes typically means a power or ground issue. Do some searching for schematics and I bet you find they all have a common ground or a common power supply.
    You might be able to fix this up with one fuse or ground wire
  9. #9 Re: 7 codes.....yay....not... HELP!
    Round lake, IL
    Ah darn it, I am so bad at that too....I do know I have a bad thermostat+ my waterpump and LIM are leaking coolant.
  1. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  2. Ecu codes
    By dmack976 in forum Engine
    Last Post: 02-11-2012, 10:39 PM
  3. Help got codes not sure what to do
    By Logan541 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-12-2011, 02:49 AM
  4. Codes
    By 3uzzkill in forum 04+ Specifics
    Last Post: 08-25-2011, 10:04 PM
  5. My car is FU**** WTF? 48 Codes
    By Toofastgs in forum General Tech Discussion
    Last Post: 12-24-2009, 10:57 AM
