Thread: Smallest pulley size to run safely...
Results 1 to 12 of 12
  1. #1 Re: Smallest pulley size to run safely...
    SE Level Member BlackGS's Avatar
    Central Jersey
    Get the Pacesetters welded and they will work fine. You will need a tune after installing headers, and should be able to run a 3.4 without KR.
    BTW, what part of NJ?
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  2. #2 Re: Smallest pulley size to run safely...
    Donating Users
    W-S, NC
    Headers would be the best choice in your quest to drop a pulley, but if money gets tight you could go with the ZZP Powerlog/plog and a 2.5 or 3 inch shorty dp. If you can weld thats the cheapest route along with a u-bend delete. If not Your local exhaust shop can do it for you. I just got my 2.5 shorty dp and u-bend delete done by a local shop on friday for $60. Just remember with any mod, make sure to scan scan scan!
  3. #3 Re: Smallest pulley size to run safely...
    Aug 2008
    New Jersey
    Quote Originally Posted by BlackGS View Post
    I'm currently in monmouth county...and I work at a full service auto shop, I think they will be able to weld for me.
  1. Boosting Pulley size
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 05:07 PM
  2. Which pulley size will work with my car?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2008, 12:18 AM
  3. pully size? (not the sc pulley)
    By SlowPurpleGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2008, 08:39 PM
  4. What would i have to do to safely run a 3.0 inch pulley?
    By John_Shughart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2008, 02:56 PM
  5. pulley size=hp?
    By underpressure2004 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:03 PM
