Thread: gtp having trouble idling
Results 1 to 7 of 7
  1. #1 gtp having trouble idling
    Nov 2008
    Birch Run
    so my 97 gtp everyone once in awhile, it's done it 3 times in a month....will start up, and have trouble idling, it's stalled a few times, after a minute of being really angry, it usually stops and idles fine. is this the fuel pump resistor problem i've heard about with these cars?
  2. #2 Re: gtp having trouble idling
  3. #3 Re: gtp having trouble idling
    Feb 2008
    I like the idea of a vacuum leak when it's cold, but I think the possibility is greater that there is a problem with the Idle Air Control Valve (IAC).
    It's worth taking off and inspecting. Make sure to get some TB cleaner and clean the pintle on the IAC as well as the IAC passages in the TB.
  4. #4 Re: gtp having trouble idling
    Quote Originally Posted by Blown97 View Post
    Good call thats what I was gonna say...or like I have suggested many times before...it could be a MAF going south on ya...but then you said it was only 3 times a month so idk...
    Maybe your car is just on the rag
    jk
  5. #5 Re: gtp having trouble idling
    Feb 2008
    Nice!!!
  6. #6 Re: gtp having trouble idling
    Nov 2008
    Birch Run
    so i remembered today, another thing...it can't be a vacuum leak when it's cold, cause it does it sometimes when it's still at operating temperature.
  7. #7 Re: gtp having trouble idling
    Feb 2008
    Quote Originally Posted by ibanez0110 View Post
    Have you done what was suggested above?
  1. This car is more trouble than it is worth
    By GothicWhiteTrash in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2010, 11:36 AM
  2. trouble codes
    By BADAZGTP in forum Forum Bugs/Suggestions
    Last Post: 07-26-2008, 10:59 AM
  3. trouble codes.
    By hotshot in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-11-2008, 06:58 AM
  4. wheel hub trouble
    By _nick_ in forum General Tech Discussion
    Last Post: 07-04-2008, 10:04 AM
  5. Trans trouble
    By landst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-20-2008, 10:52 PM
