Thread: Misfire and possible chipped piston?
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 79
  1. #1 Misfire and possible chipped piston?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    After having detonation in cyl4 (13* KR) and bending a spark plug, I have changed my plug and wire, swapped injectors and coil packs and I still have a misfire on cyl4. I have a tapping coming from the top end that goes away once the engine is warm too. I have ordered new lifters and will probably do a compression test Sunday or Monday. I am thinking bent push rod, ****ed up lifter arm, or chipped piston. It idles fine and only starts to miss under load.
    Lets discuss. I have searched the forum for chipped piston symptoms, its how I came to this idea
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Misfire and possible chipped piston?
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    what the heck were you doing to get 13* of KR?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  3. #3 Re: Misfire and possible chipped piston?
    Apr 2012
    Middletown DE
    Quote Originally Posted by TEK310 View Post
    Going WOT
    1993 Oldmobile 88
  4. #4 Re: Misfire and possible chipped piston?
    Mar 2012
    Dallas
    what happened to your tune??
    have you pulled your valve cover and looked?
  5. #5 Re: Misfire and possible chipped piston?
    Jan 2009
    Tallahassee, FL
    Wow, why do you have so much knock?
    I bet it's a chipped piston at least, the bent plug is a dead give away. Happened to me like 3 years ago. Once I finally replaced my motor I found 2 chipped pistons, she still ran so smooth like nothing was wrong.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  6. #6 Re: Misfire and possible chipped piston?
    Apr 2012
    Middletown DE
    Quote Originally Posted by Sandman View Post
    My car never normally sees more then 1-3* this time THE ONE TIME i drive it hard in months POP. I will just replace the piston(s) and hope for the best
    1993 Oldmobile 88
  7. #7 Re: Misfire and possible chipped piston?
    go to google and look up home made inspection cameras, they cost about 45 bucks to make so they say.
    then you can take a peek inside and see the piston.
  8. #8 Re: Misfire and possible chipped piston?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  9. #9 Re: Misfire and possible chipped piston?
    Chipped piston. I told you
  10. #10 Re: Misfire and possible chipped piston?
    Apr 2012
    Middletown DE
    1993 Oldmobile 88
  11. #11 Re: Misfire and possible chipped piston?
    Apr 2011
    Vassar, Mi
    Sure sounds like a chipped slug, it only takes a few seconds to pop one. A compression test should tell you what you need to know here. Mine was a small 3/4" piece off of #3 and the compression was 85 on 3 vs 155 on a good hole.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  12. #12 Re: Misfire and possible chipped piston?
    Apr 2012
    Middletown DE
    So the used spark plug I put in my car had a crack, it was changed and the misfire went away. We did a compression test that came back good on #4 and #1 and the tapping is still there. Going to change the lifters when i do the cam and hope for the best. I plan to still lift the head off to check valves and other things.
    1993 Oldmobile 88
  13. #13 Re: Misfire and possible chipped piston?
    Mine had 2 plugs missing the ends but after changing them still had a tick. I live with it until the motor swap.
  14. #14 Re: Misfire and possible chipped piston?
    Feb 2009
    flintnasty MI
    its a chipped piston.. Something had to close the gap of that plug, and I dont think the rod stretched.
  15. #15 Re: Misfire and possible chipped piston?
    Mar 2013
    North Ridgeville
    hi everyone im new here but i have a few questions i have a 99 gtp with a few small mods i recently swapped a 3.4 pulley and shortly after that i was getting KR but as the whether got colder it went away so i just put a 180 thermostat in yesterday so it would run cooler but right after i did it sputters when i go full throttle(WOT) or after it hits 4 psi i should also mention that when i did the thermostat i pulled one of the plugs to see if i should replace them but did not
  16. #16 Re: Misfire and possible chipped piston?
    What other mods do you have?
  17. #17 Re: Misfire and possible chipped piston?
    Antioch, IL
    from chat he has cai, 3.4 and 180tsat on stock pcm THATS it. We all voted dead motor.
    2009 Challenger SRT8
    Expert at being gay.
  18. #18 Re: Misfire and possible chipped piston?
    Some People
  19. #19 Re: Misfire and possible chipped piston?
    Mar 2013
    North Ridgeville
    Only mods are the pulley the stat after market boost gauge and flow master mufflers I runs to good to be blown
  20. #20 Re: Misfire and possible chipped piston?
    Mar 2013
    North Ridgeville
    And cold air intake
  1. misfire on number 5 piston
    By sabercat in forum Introductions/Noob Questions
    Last Post: 11-21-2012, 03:52 PM
  2. supercharger HELP!!!
    By DaytonaGTP500 in forum General Tech Discussion
    Last Post: 05-26-2012, 04:14 PM
  3. Symptoms of a chipped piston
    By Gasnmyveins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 10:54 AM
  4. chipped piston same spot second time! is my car a lemon?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2011, 11:29 PM
  5. APR chipped RS6
    Last Post: 12-30-2010, 11:58 AM
