Thread: 500 RPM idle, running rich, missfire...
Results 1 to 14 of 14
  1. #1 500 RPM idle, running rich, missfire...
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Bought a 99 GTP needed some work, replaced the rear o2, whole throttle body including sensors and the battery, no codes being thrown off, any ideas?
    I have also noticed that when I put it in reverse and I get on it the lights also dim, could this be an alt problem? Would it cause all this?
    Thank you!
    '04 MC Intimidator SS,'96 Camaro Z28 ,'98 GTP 12.9 trap
    '93 383 stroked Trans am (Crashed),
    '93 Chevy c1500 Pickup Indy500 Special edition,
    '01 VW GTI Garrett 50 trim, '98 GTX clone (Current car) Working on Top swap!
  2. #2 Re: 500 RPM idle, running rich, missfire...
    Apr 2012
    nova
    Vac leak? Start spraying the lim with carb cleaner to see if the idle picks up
    1999 gtp coupe... P&P heads, lim, and sc, comp vs cam, intake, dp and ubend
    2003 ford ranger fx4 level II- twin stick
  3. #3 Re: 500 RPM idle, running rich, missfire...
    Why would you replace the rear o2? It does nothing.
  4. #4 Re: 500 RPM idle, running rich, missfire...
    Round lake, IL
    Because one wire was torn up and it was throwing a code
  5. #5 Re: 500 RPM idle, running rich, missfire...
    Need a little more info. Are you getting front O2 and map signals?
  6. #6 Re: 500 RPM idle, running rich, missfire...
    Round lake, IL
    I'm not sure how to check for that, I don't have any codes being thrown off since I replaced the rear o2.
  7. #7 Re: 500 RPM idle, running rich, missfire...
    Take a look at them on a scanner. Map should move as the throttle % changes. O2's should be bouncing up and down after 10 seconds or so of starting.
    A low O2 reading means the heater isn't working and it's reading lean, so the pcm dumps fuel. Map not reading can also fudge up fueling pretty bad.
  8. #8 Re: 500 RPM idle, running rich, missfire...
    Round lake, IL
    I did notice that it takes a while for it to warm up also when I accelerate the temp gauge reads that its getting colder.....
  9. #9 Re: 500 RPM idle, running rich, missfire...
    If you're coolant temp sensor is bad it'll run like crap. The motor will dump fuel because it thinks it's colder than it is
  10. #10 Re: 500 RPM idle, running rich, missfire...
    Round lake, IL
    Gotcha... I will check that, where is it located?
  11. #11 Re: 500 RPM idle, running rich, missfire...
    St. Louis
    Should be sticking out of the LIM at an angle right near/below the thermostat housing on the LIM.
  12. #12 Re: 500 RPM idle, running rich, missfire...
    Round lake, IL
    Thank you, I will take a look at that
  13. #13 Re: 500 RPM idle, running rich, missfire...
    Use a real gauge that tells you your temp. Mine was acting up and telling the car it was -11* and the car ran bad and idled high.
  14. #14 Re: 500 RPM idle, running rich, missfire...
    Round lake, IL
    Looks like a bad Tstat, and waterpump+ LIM are leaking
  1. Rich at idle
    By shawnschuldt in forum PCM Tuning
    Last Post: 08-16-2011, 11:09 AM
  2. Car is running rich... I think
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:51 AM
  3. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  4. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  5. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
