Thread: Misfire and possible chipped piston?
Page 4 of 4 FirstFirst ... 234
Results 61 to 79 of 79
  1. #1 Re: Misfire and possible chipped piston?
    Actually I'm with Dan I want to know where on this site and other sites it says you can run a 3.4 pulley with no mods.
  2. #2 Re: Misfire and possible chipped piston?
    Thanks for quoting all of his quotes Dan and yes please link us to where we said you can run a 3.4 with hardly any mods.
    Yea we must have to charge him for him to believe what several of us are saying.
    04 Comp G.
  3. #3 Re: Misfire and possible chipped piston?
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    I can drop the idler pulley size on my N/A, loosen up that belt tension and free up tons of power. Then put in platinum quad prong plugs and wwwwwhhoooooaaaaaaa race car!
  4. #4 Re: Misfire and possible chipped piston?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    wooooooooooooooooooow
    What
    happened
    here?
    Well update I bought gasket and head bolts today. The rear side of the engine would be the right side correct? assuming i ordered the correct one.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  5. #5 Re: Misfire and possible chipped piston?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Depends on which way your looking at the car. If your staring at your engine from the front of your vehicle, wouldn't the rear be the left side? I suppose I am not completely sure.
  6. #6 Re: Misfire and possible chipped piston?
    Jan 2009
    Tallahassee, FL
    I think when discerning lest from right, imagine if the car was RWD (lol) and the passenger side would be the right side.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  7. #7 Re: Misfire and possible chipped piston?
    Apr 2012
    Middletown DE
    Hey guys, guess what.............................................. ............................................
    Misfire and possible chipped piston? Attached Images
    1993 Oldmobile 88
  8. #8 Re: Misfire and possible chipped piston?
    good one. i see rings............................................. ..............
  9. #9 Re: Misfire and possible chipped piston?
    Apr 2012
    Middletown DE
    Whats awful is that the best its ever ran/pulled was after this happened. My friends dad said that engines always run the best right before they blow up.
    I am rebuilding the entire thing
    Diamond Forged Pistons with L32 rods all new bearings and whatever else is needed.
    The pistons/rods are used with 14k on them I believe
    1993 Oldmobile 88
  10. #10 Re: Misfire and possible chipped piston?
    Howell, NJ
    Quote Originally Posted by acidcrashdburnd View Post
    Well at least your hood didn't fly up in that last pull.
  11. #11 Re: Misfire and possible chipped piston?
    Apr 2012
    Middletown DE
    Quote Originally Posted by Jomamma View Post
    Been there done that. It's why I have a silvermist car with a black hood
    1993 Oldmobile 88
  12. #12 Re: Misfire and possible chipped piston?
    Feb 2009
    flintnasty MI
    I like L67 rods better personally.
  13. #13 Re: Misfire and possible chipped piston?
    yeah, thats pretty much the rule, they run their best right before they go boom.
  14. #14 Re: Misfire and possible chipped piston?
    GT Level Member Shiftingshaddow's Avatar
    KC
    put a 3.4 on thursday. it ran good from stop at wot but it would kind of bog at wot at speed. a vacuum came loose and my fix was ok tursday but started leaking friday again. it had stock grade delco plugs so i pulled them and put auto lite 104s and new plug wires friday night and fixed my vacuum better (at the t under the s/c). drove it today and its great.
    the reason i'm posting is b/c someone mentioned a ticking noise. i have one too but i'm pretty sure its been that way for awhile. its hard to remember sometimes and then the last two posts where it goes boom after running so well because i couldnt be happier with it.
    all the plugs looked normal when i pulled them.
    it seems like the auto lites are what made the difference. the old plugs werent really in bad shape, just stock. one was not matching, though.
    so my other mods when the swap was done....zzp dp with cat, cone intake, zzp 1.0 pcm, 180 tstat. i had a hunch it should have different plugs but i've read it a couple different ways. i only drove it a day and half and not too hard except to test it out a couple times. after the plugs is all good. my vacuum still kinda sucks so i would like to clean it up more. and i pulled the 180 and put the stock back in today. it always ran at 195 anyway. and it was leaking....
    i hope no boom for me. i dont know why i'm posting, really. hoping someone will say it will be ok, i guess.
    i know, get headers....i've herad it the other way, too. hoping the people chime in who are not running headers with same mods. --no cel, by the way. i've had misfire on other car before--cel comes on.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  15. #15 Re: Misfire and possible chipped piston?
    Jan 2009
    Tallahassee, FL
    The injectors can tick pretty loud sometimes, pretty normal on GMs
    77 Morris Garage B
  16. #16 Re: Misfire and possible chipped piston?
    KC
    yeah, now that you mention it all three of my gtp's had that same noise more than once that i can remember. the van does it too sometimes.
  17. #17 Re: Misfire and possible chipped piston?
    Apr 2011
    Vassar, Mi
    Too bad about the chipped piston. It does give you an excuse to put some goodies in though. When mine popped it sounded like I broke a rod for a good 3 or 4 minutes. The whole engine was shaking and knocking. I babied it home and by the time I got home it just had a little putter to it and all the knocking and clattering was gone. Almost sounded normal. Started digging and found a smashed plug though so I just yanked the motor and trans and went through them both.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  18. #18 Re: Misfire and possible chipped piston?
    Jan 2009
    Tallahassee, FL
    In the mean time you can throw the motor back together and it'll run fine for quite a while till you get a new motor. It's not an immediate death sentence for the motor.
    77 Morris Garage B
  19. #19 Re: Misfire and possible chipped piston?
    Apr 2012
    Middletown DE
    I bought every thing required to rebuild it from zzp/intense/GM
    will start this Thursday.
    1993 Oldmobile 88
  1. misfire on number 5 piston
    By sabercat in forum Introductions/Noob Questions
    Last Post: 11-21-2012, 03:52 PM
  2. supercharger HELP!!!
    By DaytonaGTP500 in forum General Tech Discussion
    Last Post: 05-26-2012, 04:14 PM
  3. Symptoms of a chipped piston
    By Gasnmyveins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 10:54 AM
  4. chipped piston same spot second time! is my car a lemon?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2011, 11:29 PM
  5. APR chipped RS6
    Last Post: 12-30-2010, 11:58 AM
