Yeah it's most likely an intake gasket. The fuel rail is pretty easy to remove, 4 nuts the just lift up. Caution: If your a smoker give it up while doing this as some fuel spillage should be expected. Make sure to replace all 12 of the injector o-rings. Use a light oil to lube them up when reinstalling them into the head. Good luck!!!
