Thread: Help with S/C gasket and fuel rails for a top swap
Results 1 to 10 of 10
  1. #1 Help with S/C gasket and fuel rails for a top swap
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    So I finally got the body(GT) I want and now I'm ready to drop in the freshly bored L67 motor. I have 2 questions for those that might have done this swap or anyone with knowledge on the matter...
    q1) My 2 week old S/C gasket has a hole wearing in it. It seems coolant is coming through the pcv?! This is the third gasket in 2 months, wtf?! Pics below...
    q2) My fuel lines are completely different on the GT. Do I have to use the GT fuel rails in this engine swap?
    Thanks in advance!
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: Help with S/C gasket and fuel rails for a top swap
    Use l67 rails
  3. #3 Re: Help with S/C gasket and fuel rails for a top swap
    May 2008
    Schuyler, NE
    Have you pulled the PCV out to see what it looks like?
  4. #4 Re: Help with S/C gasket and fuel rails for a top swap
    Oct 2012
    New Jersey
    Yes, put in a new valve with the new gasket just a couple weeks ago... I don't understand why it's getting wet...
    I also have my LIM modded so the coolant ports to the TB are blocked.
  5. #5 Re: Help with S/C gasket and fuel rails for a top swap
    Oct 2012
    New Jersey
    Anyone?? I need to re-install yet another new gasket but I would like to fix the issue first.
  6. #6 Re: Help with S/C gasket and fuel rails for a top swap
    1. Take your gasket and lay it on the LIM. Note the postiion of the PCV hole and the rtv line they give you. Now put it on the charger and make the same notes.
    Gasket
    LIM
    Charger
  7. #7 Re: Help with S/C gasket and fuel rails for a top swap
    #2 Many say they are able to twist/turn the ends of the fuel lines and get them to work. I replace with braided, dorman repair kit etc.
  8. #8 Re: Help with S/C gasket and fuel rails for a top swap
    Oct 2012
    New Jersey
    Bill, I don't quite understand what you said in your first post. What's the "Rtv line"? And, after I make my marks like you said, do I cut the gasket? I'm confus
    Thank you for your #2 answer. I ordered the Dorman kit.
  9. #9 Re: Help with S/C gasket and fuel rails for a top swap
    Just make sure things line up and you have some RTV around the holes. That way it's sealed.
  10. #10 Re: Help with S/C gasket and fuel rails for a top swap
    MMMM I may have been thinking about the Gen V offset. See the difference in pcv location etc
    If your gasket lines up to your charger and LIM, then ensure your pcv isn't being restricted anywhere else.
  1. WTB: L67 Engine Harness, Computer, Fuel Rails and Fuel Injectors
    By trailtoy83 in forum Wanted To Buy - Parts
    Last Post: 03-07-2013, 03:10 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
