Thread: engine stalling...
Results 1 to 3 of 3
  1. #1 engine stalling...
    Donating Users PonchoDvr4Lfe's Avatar
    Feb 2008
    Kent, OH
    So I installed a SLP CAI about three weeks ago. Shortly after that (say three days), the engine would suddenly drop rpm's during normal acceleration. Accels fine when you punch it though. Could it be a possible fuel pump problem? Possible the oil from the filter is messin something up? I am heading down to intense on Friday to have them change out my S/C snout seal and put on an MPS. I will probably have them reprogram my computer to their basic set-up and then change out my plugs and wires to 605's and MSD wires.
    I am stuck on this one...
    04' GP GTP Comp G, 08' G8 GT, 10' Camaro 2SS
  2. #2 Re: engine stalling...
    SE Level Member zeppelinrocks18's Avatar
    Quote Originally Posted by PonchoDvr4Lfe View Post
    When you say the RPM's drop off during normal acceleration, does it drop off DURING acceleration, or after you let off the accelerator? So, if you do a normal acceleration, and let go to coast, is that when it does it? Also, is the SES idiot light on? Any codes?
    1998 GTP, 118K, Short Ram Air Intake, ACDelco RapidFire Plugs, Belden Wires, Resonator and U-Bend delete, Flowmaster Original 40 Series, KYB GR-2 Struts, 180* Thermostat
  3. #3 Re: engine stalling...
    Feb 2008
    Kent, OH
    No codes, no lights, and it's during acceleration not after. Ex: If I give it 50% throttle from a stop, it happens consistently 1st through 3rd gears. Although it much more noticeable in 2nd and 3rd gears. And this only occurs when the car is cold. For maybe the first five minutes of driving or so.
  1. Intermittent Engine Stalling Problems
    By BADAZGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-23-2010, 10:46 AM
  2. Car keeps stalling out
    By SD GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 07:43 PM
  3. another GTP stalling out sometimes
    By daryls377 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2008, 07:42 AM
  4. random stalling
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 08:28 PM
  5. Intermittent Engine Stalling Problems
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-16-2008, 07:59 AM
