Thread: worried plez help
Results 1 to 12 of 12
  1. #1 worried plez help
    SE Level Member Charged97's Avatar
    ATLANTA
    well here it goes i went campin and left my car sittin 4 3 days come back and there is a meduim size fluid under my car (oil i think) so i check the dip stick it seems ok so i drive home 5 min away i get home open the hood oil buring smell i look under a few lil drops droped down for a few sec i get under the car all the undercarrage above has signs of a lot of oil leak not the oilpan it seems good my guess is that the rear valve cover gasket is shot dugh its a 97 hell it should be shot what do u guys think please tell me its not the headgaskets plus my oil looks clean still thanks
  2. #2 Re: worried plez help
    Oklahoma
    Having no specific information, I assumed you have a GTP, if not I'll move it to the correct section.
    As well, I would call your attention to this thread, post #7
    http://www.grandprixforums.net/f14/a...read-6828.html
  3. #3 Re: worried plez help
    Feb 2008
    Quote Originally Posted by Charged97 View Post
    Not likely head gaskets. Most likely the problem is your valve cover gaskets. Make sure to also pay attention to the oil pressure sensor as they tend to get old, crack and leak.
  4. #4 Re: worried plez help
    ATLANTA
    yea i looked under the car and looked up and i seen oil resedu quit a bit all the wayup buy the valve covers would the oil pressure sensor spray or jusy leak u think it would spray all the way up there oh and 2 day nothing was leaking all day im confussed
  5. #5 Re: worried plez help
    Feb 2008
    Yeah the oil sensor is under the full pressure of the oil pump. So it could spray all over, but sometimes depending on the condition they can leak or seep oil too. If you see oil all the way down your engine block it's your valve cover gaskets. Keep in mind that the front valve cover has a recall on it. A way to see if your oil pressure sensor is leaking is to start the engine and get into a position where you could look directly at it. If it is leaking you will see it.
  6. #6 Re: worried plez help
    Jul 2008
    Germantown, Maryland
    Isn't there a recall for this issue?
  7. #7 Re: worried plez help
    ATLANTA
    ill try and c whats up thanks 4 the help thanks alot
  8. #8 Re: worried plez help
    SE Level Member zeppelinrocks18's Avatar
    The recall is only for the front valve cover gasket. Had to get mine replaced. Got mine done a year before they recalled though. Got ripped off out of some money from GM. It's most likely the valve cover gasket though. Keep us posted if you find anything out.
    1998 GTP, 118K, Short Ram Air Intake, ACDelco RapidFire Plugs, Belden Wires, Resonator and U-Bend delete, Flowmaster Original 40 Series, KYB GR-2 Struts, 180* Thermostat
  9. #9 Re: worried plez help
    PA
    Quote Originally Posted by Quicklynx View Post
    There is a recall for the front valve cover gasket. But they don't touch the rear, as far as I know. But if it is in the shop and going to be torn down, maybe they can give you a deal on it.
    But I would suspect you need to change the valve cover gaskets and oil pan gaskets. And if these are that bad, you might want to consider changing your Lower Intake Manifold Gasket. All of these were bad on my 97 at 150k miles.
    2001 GSE
  10. #10 Re: worried plez help
    Jul 2008
    sumter,south carolina
    call GM with ur vin number and the can tell u if u qualify for recall.
    02 GTP with mods 05 GP for DD
  11. #11 Re: worried plez help
    Feb 2008
    Quote Originally Posted by zeppelinrocks18 View Post
    Do a little more research on this because I don't know the details but we were supposed to get reimbursed for the cost of that front gasket if we got it done before the recall. I got mine done too before the recall so I would be interested, just haven't looked into it before.
  12. #12 Re: worried plez help
    Quote Originally Posted by Blown97 View Post
    They do reimburse you for the front valve cover gasket but they decide what the correct price is. So they didn't give me the price I paid for it but they did give me back the majority of the price.
  1. need asap plez
    By Charged97 in forum General Tech Discussion
    Last Post: 09-29-2008, 11:51 PM
