Yea, as funny as it sounds, they are NOT re-useable. Maybe if you just put the motor together and only went 1,000 miles or so... but I would just buy new. GM changed to the metal gaskets because the Dexcool was breaking down the plastic compound the original gaskets were made of, causing leaks.
Unless you ok with risking a leak inside the motor... just get new ones.
